Anti roll bar
- mark1971
- Visitor
21 Jul 2011 07:08 #19297
by mark1971
Anti roll bar was created by mark1971
I was thinking of removing the anti roll bar to help the wheels stay on the ground when I'm off roading. The question is will the increased movement of the front axle cause issues with the standard length brake hoses? I'm lifting the car 3" next month and if there could be issues I will just wait until I've extended the brake hoses as part of the lift.
Cheers Mark
Cheers Mark
21 Jul 2011 07:21 #19298
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Re: Anti roll bar
If you are removing the anti roll bar you will need longer brake hoses and it will save you time when you do the lift later.
2002 JLX Soft Top
- mark1971
- Visitor
21 Jul 2011 07:24 #19299
by mark1971
Replied by mark1971 on topic Re: Anti roll bar
Cheers for the quick response. I'll leave it alone for now since I've not bought the lift kit or hoses yet.....roll on pay day ( woo hoo ).
21 Jul 2011 07:31 - 21 Jul 2011 14:56 #19300
by dirtydogz
2002 JLX Soft Top
That OK mate we are here to help.
Martin has the longer hoses in stock and no vat to pay
good luck.
DIRTYDOGZ
www.bigjimny.com/store/index.php/jimny-p...hose-sets/p_122.html
good luck.
DIRTYDOGZ
2002 JLX Soft Top
Last edit: 21 Jul 2011 14:56 by dirtydogz.
- Adamski
- Visitor
21 Jul 2011 15:59 #19311
by Adamski
Replied by Adamski on topic Re: Anti roll bar
I took the anti roll bar off for the same reason about 6 months ago. I got fed up with the car flopping about so this morning I refitted it (with new anti roll bar links) and I cannot believe how much better it is to drive with the anti roll bar fitted.
If you don't do much on road driving, take it off. Otherwise leave it on as you will soon get sick of wobbling about round corners.
Just my 2 pence
Just my 2 pence
- Az1987
- Visitor
21 Jul 2011 16:42 #19314
by Az1987
Replied by Az1987 on topic Re: Anti roll bar
Just a quick side note it is now a MOT fail to remove a anti-roll bar from a vehicle that left the factory with one.
Time to create page: 0.156 seconds
