Broken chassis end eye of panhard rod
- Collins
04 Jun 2011 16:41 #17338
by Collins
Broken chassis end eye of panhard rod was created by Collins
Has this happened to anyone else? -Everyone says they've never seen anything like it. The eye has obviously been broken for some time given the patina on the broken ends. It's broken in a curved shape round where the rod is welded to the eye. It looks like the eye has then stretched over time until it has finally snapped on the other side. The first break wasn't visible because it was on the upper side of the eye hidden in the bracket. Needless to say, it was a bit scary when I lost steering but I was lucky to be on a quite straight bit of road going slowly!
According to Suzuki this is normal wear and tear at 55,000 miles and 7 years! I have only done very light green laning because I drive this every day - so it's had a pampered life really.
- NickG
04 Jun 2011 17:22 #17342
by NickG
Replied by NickG on topic Re: Broken chassis end eye of panhard rod
If you need panhard rods i have a pair with good bushes
just PM me.
just PM me.
- Collins
04 Jun 2011 18:10 #17344
by Collins
Replied by Collins on topic Re: Broken chassis end eye of panhard rod
Thanks very much but I've just fitted a nearly new one at the front and the rear one is ok.
- supergaz
04 Jun 2011 19:40 #17355
by supergaz
Replied by supergaz on topic Re: Broken chassis end eye of panhard rod
More like component failure, that could have been very nasty.
- Collins
05 Jun 2011 06:58 #17360
by Collins
Yes, that's what everyone except Suzuki GB think so make sure you check your panhard rod eyes carefully by actually disconnecting them and checking all round. Several mechanics obviously didn't spot this so I'll be doing everything except welding myself from now on. As it happens I was doing under 30 on a quiet straight road. I hate to think what would have happened had I decided to go home the other way . It would have been 60 mph on a winding A road. Doubt I would have missed everything. This is my 3rd and last Suzuku. I am really disappointed with the Jimny compared to the Samurai I had. I mean, pathetic bearings, no steering damper, rubbish bushes and components. I might feel diffferently when I get over the shock and the amazingly patheric response from Suzuki. I would want to know if a failed component had nearly killed someone.
05 Jun 2011 08:07 - 05 Jun 2011 08:08 #17362
by facade
Replied by facade on topic Re: Broken chassis end eye of panhard rod
Everything is built down to a price nowadays.
If you compare a brand new Landrover to one produced in the 60s or 70s you could say the same.
Poor quality components, thinner chassis, weaker bearings shabby paint, they don't even galvanise the body cappings anymore.
On balance, I prefer my Jimny to the Landrovers I've had, if the Jimny was permanent 4wd it would be pretty near perfect.
Last edit: 05 Jun 2011 08:08 by facade.
Time to create page: 0.404 seconds
