sj rim - tyre size?
- doncarlyon
17 May 2011 18:38 #16461
by doncarlyon
sj rim - tyre size? was created by doncarlyon
will a 215 be ok?
- Sandez
18 May 2011 00:50 #16470
by Sandez
Replied by Sandez on topic Re: sj rim - tyre size?
We need a little bit more information, but both a 215/70/15 and 215/75/15 will fit with no modifications but I dont believe a 215/80/15 would fit witout modification.
Read this for the sizes and the modofications needed for what size.
Also search the forums as there are numerous threads with plenty of information on this.
About tyre sizes:
Of a 215/75/15 tyre, the 215 tyre refers to the width of the tyre, the 75 refers to the aspect ratio of the sidewall to the width of the tyre and the 15 refers to the size of the rim to fit the tyre.
About tyre sizes:
- doncarlyon
18 May 2011 05:18 - 18 May 2011 05:19 #16473
by doncarlyon
Replied by doncarlyon on topic Re: sj rim - tyre size?
I know all about tyre profiles and the car is already lifted, etc. All i need to know is if a 215 is too wide for an SJ rim?
Ive got an SJ rim as a spare on my Jimny and it has a different size tyre to the other wheels plus its seen better days. So was just looking at putting a new tyre on it.
Or will I have to buy another Weller wheel like my other 4?
Last edit: 18 May 2011 05:19 by doncarlyon.
- Sandez
18 May 2011 08:22 - 18 May 2011 08:23 #16479
by Sandez
This may vary depending on the brand of tyre etc. so it would probs be best to speak to the tyre fitter to make sure
However, based on this information from one of the General AT2 tyre sizing charts, the 215/75/15 wheels are suited to a 5.5 to 7.0 wide rim. Given the standard rim is 15x5.5 it should be fine.
Some people have fitted oversized tyres for their rims without issues before.
Last edit: 18 May 2011 08:23 by Sandez.
- doncarlyon
18 May 2011 09:08 #16486
by doncarlyon
Cool cheers!
22 May 2011 07:27 #16700
by kirkynut
Replied by kirkynut on topic Re: sj rim - tyre size?
Any 215 will fit an SJ run - I run 215/80/15's on SJ rims.
They are the same dimensions as a Jimny rim but with 5mm less offset.
In fact you can run 235's on an SJ or Jimny rim.
