Gear stick vibration.?
  • Asbojimny
02 May 2011 19:36 #15797 by Asbojimny
Gear stick vibration.? was created by Asbojimny
Seems worse on harder ground when off roadin'. Sometimes not noticeable at all.Selects gears no problem,but when climbing uneven hard ground the gear stick vibrates,a kinda rattle i guess.
Anyone got a clue what could cause this?
Cheers
03 May 2011 19:44 #15829 by Halford
Replied by Halford on topic Re: Gear stick vibration.?
Hi, I'm no expert but as no one has replied, thought I'd chip in - I had stick vibration (also steering column vibration) and a road car, that varied and it was down to a failed rear engine mounting - might be worth inspecting as it should be visually evident if there's an issue.
  • darthloachie
04 May 2011 06:08 - 04 May 2011 06:09 #15841 by darthloachie
Replied by darthloachie on topic Re: Gear stick vibration.?
Might be worth checking the transfer box mounts
After a bit off ambitious offroading (following a v8 jeep) I had a bolt snap on mine :blush: - the gearstick rattled and you could feel the vibration when you rested your hand on the gear stick
Last edit: 04 May 2011 06:09 by darthloachie.
  • Asbojimny
08 May 2011 15:04 #16036 by Asbojimny
Replied by Asbojimny on topic Re: Gear stick vibration.?
Cheers guys. Had a wee look this afternoon and transfer mounts seem ok. There is slight movement on the nearside engine mount,on the engine side so will have a better look during the week. :)
  • VAXXi
25 May 2011 09:54 #16924 by VAXXi
Replied by VAXXi on topic Re: Gear stick vibration.?
Hi everyone,
I'm sticking to this topic as my problem seems similar. Even when driving on good tarmac, the gear stick constantly vibrates. I will try to make a video showing the problem, but visually it's about 1 centimeter in amplitude from left to right. Vibration frequency seems to increase with speed.
Is this normal (i.e. "they all do that") or should I start investigating the transfer box and engine mounts?
Cheers!
25 May 2011 10:35 #16928 by Halford
Hi VAXXi
my 2007 std (no lift) is rock steady, no vibes at all
- even when the engines running :silly:
Time to create page: 0.182 seconds
