HELP :(
  • bertbuckie
30 Apr 2011 09:51 - 01 May 2011 18:48 #15666 by bertbuckie
HELP :( was created by bertbuckie
My jimny is dying :(
I got the back all welded ( I will upload pics one day ) and painted the entire inside ( under carpet, plastics.... the lot :) )
And had a good look under the bonnet at the rust by the headlights :(
It seems that there is a hole the size of my fist to the side of the passengers headlight..... right next to the front body mounting.... and the other sides similar but not as bad.
From looking at it you cant just unbolt the front piece that its on, or the bit to the inside of the headlights.
I am going to get a professional welder to take a look but I am sceptical if it will cost more than the cars worth broken..... be a real shame to break her :(
Anyone got any tips or anyone elses the same ?
Attachment S8301025.JPG not found
Attachment S8301026.JPG not found
Attachment S8301027.JPG not found
Last edit: 01 May 2011 18:48 by mlines.
  • NickG
30 Apr 2011 13:46 - 30 Apr 2011 13:50 #15673 by NickG
Replied by NickG on topic Re: HELP :(
Dont stress fella :) :)
A good welder should sort this out for you
in a few hours
i had fist size holes about 3" from the front
body mounts (out riggers ) and it took me
about a hour a side, The slow bit is cleaning
up all the new black crap you have just
sprayed on it. Its not ready for the scrap yard just yet
Chin up old boy.:P :P
Last edit: 30 Apr 2011 13:50 by NickG.
  • NickG
01 May 2011 20:13 #15722 by NickG
Yep i take that back that is stress y
sorry mate
if you were down here in the south i would be happy
to weld it up for you
  • bertbuckie
02 May 2011 05:33 #15725 by bertbuckie
Replied by bertbuckie on topic Re: HELP :(
NickG wrote: Yep i take that back that is stress y
sorry mate
So it is fixable?
what do you recon a normal garage would charge?
  • NickG
02 May 2011 06:36 #15731 by NickG
Fix able YEP
can you plate up the hole and rub down the
other bits it looks like the bits on the seams
is just surface rust.:unsure: :unsure:
Then give it all a good couple of coats of red oxide
have you got any more pictures
  • bertbuckie
02 May 2011 06:40 #15735 by bertbuckie
No, but I can get more today and will be back at a house with broadband so can upload them later :)
Time to create page: 0.200 seconds
