Random rough idling, getting worse
- RockmanRock
13 Apr 2011 09:24 - 13 Apr 2011 09:25 #14945
by RockmanRock
Random rough idling, getting worse was created by RockmanRock
Hi all, can anyone pls help shed any light on a problem with idling I am having on my 06.
In summary, it has started missing a beat when sitting at idle - like a misfire, but there is no warning light. It's a pretty violent miss, as the shake carries through to the whole car. It started doing this more and more over a couple of weeks, and when it went in the garage, they replaced the plugs (which weren't that old since I last did them). This cleared it up for another couple of weeks, but it has no started doing it again. The symptoms are:
Any ideas?? I was thinking maybe 02 sensor issue, or something like that causing a buildup on the plugs? Other alternative is a weak HT lead or coil - I've experienced failing coil pack on another car - but I would have thought that would happen regardless of engine being hot or cold, and wouldn't explain why new plugs fixed it for a couple of weeks. I'm keen to get it sorted as I have a big trip coming up and can't be worrying about it cutting out once outback.
Advice appreciated,
Cheers,
Rob
- * Only does it when the engine is warmed up
- * Seems to happen more often with load at idle i.e. aircon on
- * randomly misses a beat, no set interval. maybe about once a min, sometimes a few times?
- * gets progressively worse over a few weeks
- * does not cause the check light to come one, and neither has it put any error codes
- * no issues driving
- * went away with new sparkplugs for a while, then came slowly came back
Advice appreciated,
Cheers,
Rob
Last edit: 13 Apr 2011 09:25 by RockmanRock.
- ooky_123
13 Apr 2011 10:26 #14947
by ooky_123
Replied by ooky_123 on topic Re: Random rough idling, getting worse
Sounds similar to a sensory issue .. Crank or Camshaft sensors give similar issues when hot. although these do tend to also happen when you are driving.
Might be best to check them.
13 Apr 2011 17:21 #14967
by facade
Replied by facade on topic Re: Random rough idling, getting worse
Coil.
Had the same on my MotoGuzzi.
Some days it would just cut out when I came to a junction, ran like a pig, but fine when moving.
Other days, or when ever I messed with it, e.g. new plug caps: the idle speed was higher and perfect.
Never put the diagnostic light on either.
Swapped one of the coils out and the problem went away.
Can't remember how I decided which coil it was though........
My jimny has an irregular miss at idle, seems the same symptoms as the 'bike, I've just changed the plugs: no difference, so I will get another coil when I see one cheap on eBay.
- RockmanRock
13 Apr 2011 20:34 #14995
by RockmanRock
Replied by RockmanRock on topic Re: Random rough idling, getting worse
Thanks for the replies. I can get my hands on an ignition coil cheaper (and swap it over quicker) than a O2 sensor, so I guess I'll try that first and see what happens. If not, it's still a good small part to fit into the spares cubby on board...
- ooky_123
13 Apr 2011 22:40 #14997
by ooky_123
Not an O2 sensor .. Crank and cam position sensors. they retail for about £50 each in the UK
- RockmanRock
13 Apr 2011 23:00 #14998
by RockmanRock
I would have thought a position sensor failure would cause bad idle across the board, not just when cold? And the change of plugs did fix it for a while. Although I suppose it could be the heat getting to the cam sensor...
