Help me with the timing belt change (please?!)
  • distantcamera
06 Apr 2011 12:33 #14596 by distantcamera
Help me with the timing belt change (please?!) was created by distantcamera
Hi folks,
Attempted the timing belt change today but we ended up putting the car back together and surrendering for the day :(
It looks like you have to take the crank pulley off to get the timing belt cover off, but how on Earth do you undo the crank nut without just turning the engine? Putting it in gear don't work! One suggestion made was to take a sparkplug out and feed rope into the hole which will lock up the engine. Anyone ever heard of this being done? We couldn't try that either actually as I have to go and buy a new plug socket which will fit in the tiny, tiny and yet so deep little hole that the spark plugs live in...
So any pointers from those who have succeeded would be most welcome :D
  • vitara_mad
06 Apr 2011 16:26 #14607 by vitara_mad
you dont undo the big bolt on the bottom pully just the little 8mm ones they should come undone easy enough
once you got cover off its a easy task to change the belt & tensioner just line the markings up remove old belt & tensioner & replace
ive only ever changed one timing belt & that was a jimny couple of months ago ive always been a bit scared of doing them in the past but i was supprised just how easy it is to do
  • distantcamera
06 Apr 2011 16:31 #14610 by distantcamera
Replied by distantcamera on topic Re: Help me with the timing belt change (please?!)
vitara_mad wrote: you dont undo the big bolt on the bottom pully just the little 8mm ones they should come undone easy enough
Ah, bugger. Thanks :D
06 Apr 2011 20:39 #14643 by facade
If ever you do want the big nut undone, the bodger's way is to get a good fitting socket and a cracker bar, and fit it so that the bar is resting under the chassis rail on the drivers side. then flip the starter.
It is a sensible plan to disconnect the coils first, but I've never been sensible.
  • distantcamera
07 Apr 2011 17:18 #14669 by distantcamera
Interestingly the guy who was changing the belt for me phoned the local Suzuki garage this morning to ask them about it (he views the internet as witchcraft). They said that the big nut definitely had to come out.
So I tracked down the service manual and it clearly says that only the little nuts have to come out. So I won't be taking my Jimny into the Suzuki place in the near future!
  • Little Terror
07 Apr 2011 18:39 #14678 by Little Terror
Replied by Little Terror on topic Re: Help me with the timing belt change (please?!)
Another good way of undoing nuts like this were by you can not lock the shaft in any way is to use a pneumatic air gun like the ones they use in garages to take your wheels of.
Time to create page: 0.260 seconds
