HEATER BLOWING COLD
  • myers647
28 Mar 2011 18:02 #14197 by myers647
HEATER BLOWING COLD was created by myers647
Eyup everyone ,I got in my Jimny this morning and the heater will only blow cold air ??
Has this happened to anyone else, is it a common fault ? or what could it be???
Thanks
  • Brian.SMC
28 Mar 2011 18:06 #14198 by Brian.SMC
Replied by Brian.SMC on topic Re: HEATER BLOWING COLD
Could be minor, ie thermostat or a matrix blockage or similar.
Worse the head is feced.
  • myers647
28 Mar 2011 18:22 #14205 by myers647
Replied by myers647 on topic Re: HEATER BLOWING COLD
ok cheers mate.
  • mcjimny
28 Mar 2011 18:43 #14209 by mcjimny
Replied by mcjimny on topic Re: HEATER BLOWING COLD
yep sounds like the stat, simple fix. If your top hose is getting warm slowly its stuck open, if its not getting hot at all its stuck shut of course. It should be cold then suddenly get hot once the stat opens, you can test them in water but once its out to do that you may as well throw a new one in.
  • myers647
28 Mar 2011 18:52 #14212 by myers647
ok mate il try it tmoro.
thanks
29 Mar 2011 05:09 #14223 by mlines
Replied by mlines on topic Re: HEATER BLOWING COLD
Usual problem with "instant heater fail" is someone has kicked and broken (or dislodged) the plastic actuator on the side of the heater under the dashboard, handily positioned just where you can kick it.
Time to create page: 0.221 seconds
