New steering wheel on old Jimny?
  • distantcamera
13 Mar 2011 00:12 #13219 by distantcamera
New steering wheel on old Jimny? was created by distantcamera
Is it possible to fit the new steering wheel from a facelift Jimny onto an old 1999 without major headaches?
Suzuki seems to have made my steering wheel out of an old sponge :( I presume that I'd need it complete with airbag, but would that (and the horn switch) plug straight into my wiring?
  • goatboy
13 Mar 2011 07:58 #13223 by goatboy
Replied by goatboy on topic Re: New steering wheel on old Jimny?
My old steering wheel fell apart too! Got a replacement from a scrapyard for 30 quid. Not sure if it is from a later model but it is a slighty darker grey. I reused the existing air bag no problem. Just means I have a 2 tone wheel. It's kinda cool. B)
  • distantcamera
13 Mar 2011 18:11 #13262 by distantcamera
Replied by distantcamera on topic Re: New steering wheel on old Jimny?
Yes, I had thought of sourcing another pre-facelift one, but I quite fancy one of the nice leather jobbies fitted to the newer ones :)
Nobody else has though of trying this? How much of a pain is it to get the steering wheel off? Maybe I'll be the first to try. How would I tell if the airbag was going to work ok?
13 Mar 2011 18:58 #13266 by facade
You need to make a puller to remove the wheel, there should be 2 threaded holes in the wheel when you remove the airbag gubbins.
Don't use the old trick of slackening the nut, and banging both hands hard on the wheel rim to get it off, the steering column has plastic shear pins inside so it can collapse in an accident.
  • distantcamera
13 Mar 2011 19:12 - 13 Mar 2011 19:12 #13270 by distantcamera
Aha! Thanks for the warning; I'd have probably tried to bash it off :blink:
Last edit: 13 Mar 2011 19:12 by distantcamera.
  • darthloachie
13 Mar 2011 19:50 #13288 by darthloachie
Replied by darthloachie on topic Re: New steering wheel on old Jimny?
distantcamera wrote: Aha! Thanks for the warning; I'd have probably tried to bash it off :blink:
that brings back memories
I was helping my mate get the steering wheel off his MGB (yes I am that old) and he said you pull while I hit it with a hammer
his famous last words were .............
don't worry I won't hit your hands!
Time to create page: 0.290 seconds
