Gen4 steady throttle power loss
- Thank you received: 1999
08 Mar 2026 10:14 #263938
Gen4 steady throttle power loss was created by Lambert
Just started this morning. First instance on a flat road 40mph 4th gear, power dipped for less than a second and came back almost like having dirt in a carburettor jet. Then 2 short stops and one off road section later second gear 15 mph definate drop in power, foot to floor no picking up revs, dip clutch revs build engage clutch power drops again. Out onto main road 2.5 miles no issue mixed gear, loads and up and down incline and level. On rtb only 3 codes relating to old tyre pressure and 2 relating to be lidar esp system communications which I imagine would be something to do with the brake lights fuse going out. No codes relating to general obd11 or engine system or limp mode?
Anything anyone successfully dealt with?
08 Mar 2026 20:44 #263941
by facade
Replied by facade on topic Gen4 steady throttle power loss
No clue I'm afraid, but if it doesn't think anything is wrong then I'd look at live data to see if there is something wrong with the throttle sensor, but you'd expect if if was an intermittent connection or loss of output that it would set a code.
You'll have to contact Suzuki and pay hundreds for a diagnostic that won't find anything (Which is where I am at the moment with my Citroen, except they won't even look at it until mid April...) Then wait until it breaks and get a warranty fix having flagged the problem already.
The only other thing that springs to mind is an obstruction in the exhaust that has cleared, like half full of water or something, but I know you avoid water over the tyres too.
09 Mar 2026 04:22 #263942
Replied by Lambert on topic Gen4 steady throttle power loss
Thank you, yeah I'm going to contact the supplier later today to get their view and register it with them so it's on the system if needed for warranty. I'll also have live data on for a few more trips and see if anything shows.
- Thank you received: 672
09 Mar 2026 13:23 #263947
Replied by DrRobin on topic Gen4 steady throttle power loss
It sounds like it’s going in to a Limp Mode, if the Jimny has such a thing and it’s possible it’s connected to the Lidar sensor fault codes.
My last BMW did the exact same when it reported a random fault with the gear box, it wouldn’t rev unless you changed down (it was an auto). It only cleared when you turned the ignition off.
It’s possible your Jimny is going in to a limp mode (or reduced speed/power) due to a Lidar fault, which then clears and it comes back out?
My anti collision has activated a few times, but never cut the power or applied the brakes.
If your Jimny does it more frequently try turning off the collision detection, if that stops the problem then you will know it’s something to do with that circuit and it’s probably a dealer repair.
09 Mar 2026 16:06 #263949
That's the thing, it's been fine since Saturday morning? I'm still inclined to think that the lidar was to do with the brake fuse. It could just have been a bit of contamination going through the injectors but I only use shell from a high volume forecourt deliberately to try and avoid bad fuel? Unfortunately until it does it again I'm a bit adrift with it.
09 Mar 2026 19:09 #263950
Replied by mlines on topic Gen4 steady throttle power loss
Anti collision has a couple of forms varying from a warning on the dashboard to a full braking and power drop. All forms are really noisy with panic alarms going off and on the braking version ABS pumping.
There was a reported mystery fault on the Jimnys reported on the press release cars in the USA where commanded and "silent" braking occurred on an empty road during a mild turn. I once had something similar in mine
Time to create page: 0.332 seconds
