Jimmy over fuelling. Cat gets red hot. Car runs fine until hot
06 Jun 2025 06:55 #260772 by ct
Morning all. Need advise. I have a 2009 1.3 jimmy. Which has developed an over fuelling issue. The cat glows red. The car runs fine until it’s hot. Then all of a sudden it starts to stutter and it cuts out. No fault codes at all. Any one had this issue. Information would be gratefully received. Thanks ct
06 Jun 2025 07:25 - 06 Jun 2025 07:26 #260773 by yakuza
Clogged cat so resistance too high?
Spark plugs?
Bad or wrong fuel?
Coils?
Any mods done to it?
These cats are prone to failure as the no 1 disintegrates and the powder and pieces fall down into the no2 cat and constricts.
Last edit: 06 Jun 2025 07:26 by yakuza.
06 Jun 2025 08:06 - 06 Jun 2025 08:07 #260774 by facade
If you just want to fire the parts cannon at it, try the pre-cat oxygen sensor. (The one on the exhaust manifold)
During warm up the engine is running on a pre set map, then when hot it tries to balance the fuelling with the reading from that sensor.
They often go bad and cause overfuelling issues (which fail MOT on emissions as well as drop the MPG, but it is gradual so you don't notice), the EML won't come on until it can't get what it thinks is a sensible reading off that sensor and runs out of fuel trim trying.
Otherwise you are going to have to start reading stored codes and examining live sensor data.
Last edit: 06 Jun 2025 08:07 by facade.
06 Jun 2025 16:03 #260792 by ct
Both cats have been changed. It runs lovely till warm then it starts to misfire and can cut out.
06 Jun 2025 17:02 #260793 by Lambert
If it's heat related it could be the cam sensor?
The following user(s) said Thank You: ct
06 Jun 2025 18:14 #260794 by ct
Time to create page: 0.396 seconds
