Master cylinder replacement
01 May 2025 11:42 #260275
by Barnes
Master cylinder replacement was created by Barnes
The master cylinder reservoir is leaking on my jimny. It’s a 2001 non abs m13a. I have a replacement with the servo etc.
My question is should I replace the servo as well or should I try to separate the new reservoir from the cylinder and replace just that?
Im a driveway novice but I would like to try to fix it myself!!
Many thanks for any help!
01 May 2025 13:56 #260277
by fordem
Replied by fordem on topic Master cylinder replacement
I'd replace the master cylinder only...
01 May 2025 19:43 #260280
by facade
Replied by facade on topic Master cylinder replacement
I'd try and replace the reservoir seals that are leaking if I could get them- then there is no bleeding or messing about under the car required
Otherwise, assuming we are talking about a second hand unit, I'd swap only the cylinder as it just detaches without the need to mess around in the footwell trying to disconnect the pedal- plus there is no guarantee that the "new" servo works and you know that yours does.
02 May 2025 13:40 #260292
by Barnes
Replied by Barnes on topic Master cylinder replacement
Yep that’s exactly what I thought, I think it is the reservoir seals that are leaking. Do you know how I can get to them? There is some sort of pin I think securing it but I don’t want to butcher it getting it off if there is a specific way to remove it??
Thanks for your help!
02 May 2025 20:43 #260293
by fordem
It's what is known as a "roll pin" (it's made of rolled spring steel) and it can be tapped out with a pin punch, which is essentially a cylindrical punch narrow enough to fit through the hole the pin is in.
If you don't have a pin punch small enough, find a suitable nail and grind the pointed tip off, you don't want to drive a pointed object into the roll pin (it's hollow) and spread it.
You might be able to grab it with a pair of nippers and pull it out.
03 May 2025 19:07 #260302
by Barnes
Ah brilliant, thanks so much for the advice! Hopefully that will make it a much easier job, it looked like a bit of a mare to get up under the dash and change the whole mechanism.
