Liftkit and death wobble
17 Nov 2024 18:27 #258360 by Lars Heede
Hello my fellow Jimnyists!
i just bought a brand new 2024 3door lcv. I have had a full 2” Ironman liftkit fitted with springs, dampers, castor correction bushes and cross member. Also I had the standard wheels replaced with a set of 15x7 Dotz Dakar Dark steel wheels with BFG KO2s in 235/75/15.
Now I have a significant death wobble (which comes and goes) at 60-65 km/h.
Any ideas on what could be wrong?
All the best from a both happy and frustrated Jimny owner.
17 Nov 2024 19:02 #258361 by DrRobin
Replied by DrRobin on topic Liftkit and death wobble
I am assuming that your LCV is very low kms so we can rule out wear on any of the components. Lifting a vehicle which has any wear in any of the components just makes the wobble worse, but that shouldn't be the case here.
I am just considering a 2" lift kit, so have already looked at this in some detail. A 2" lift is not excessive so shouldn't cause a death wobble and you have had castor correctors fitted, all of that should have been OK. The tyres are quite big, but again are doable, so we need to look for something wrong with the fitting.
Did you drive the vehicle before the lift kit and big tyres were fitted? I.e. do we have a baseline of what the vehicle was like before?
I am not sure of your experience with a vehicle like a Jimny before, but they can feel different to other modern cars oir even 4x4s due to the 'live axles' and suspension set up. However, they shouldn't have a death wobble.
Start with wheel balance, were the tyres and wheels correctly balanced? It's often hard to balance these tyres with weights and a lot of people use 'balance beads' which go inside the tyre and balance the wheels automatically.
Next, rather obvious, but is everything on the new suspension and steering arms tight?
After that, did the garage who fitted the lift kit check steering alignment?
Are the dampers adjustable on the lift kit? If they are then check the settings are the same and perhaps increase the damping force.
The springs are usually a different length and often designed for a Left hand or Right hand drive (I don't know about the Ironman kit), but did the garage fit the correct springs in the right place?
Someone else might wade in here but if it was me I would go back to the garage who fitted the lift kit and explain the problem.
Robin
17 Nov 2024 19:36 #258362 by 300bhpton
Replied by 300bhpton on topic Liftkit and death wobble
Did you have the 15x7 Dotz Dakar Dark steel wheels with BFG KO2s in 235/75/15 fitted prior to the lift or done at the same time?
If they were on before, how did it drive?
If fitted after, can you try your old wheels and tyres and see if that "fixes" it.
Wobble at a set speed all the time that you can drive through sounds more like wheel balance if honest.
17 Nov 2024 19:47 #258363 by jlines
Replied by jlines on topic Liftkit and death wobble
Like others have said work backwards from what was last done to the car or perhaps both the lift and tires were done together? As 300bhpton suggests if you can refit the old wheels and that will rule them out if it still does it. I would be very surprised if a 2inch lift has created wobble and that would be a first i've heard that has. I've got 2 that have been lifted with different kits to the one you've fitted and it didn't change really anything to how it handled so my bet would be some kind of tire balencing issue. Also a simple fix would be to check the tire pressures if a garage did them for you as many over inflate and you'll be surpised at just what effect that has on a jimny.
1986 SJ413JX (Lil Red)
2018 JB43 SZ4
2019 JB74 SZ5 (Gerald)
2023 JB74 LCV
17 Nov 2024 20:02 #258364 by Lars Heede
Replied by Lars Heede on topic Liftkit and death wobble
Thank you very much for your detailed reply. Indeed the car is brand new.
I will take all your advice to the garage who installed the kit and the new wheels/tyres.
I did drive the car for a few days before having the upgrades done. From the dealer it came on standard suspension with original 5,5” alloys and 215/75/15 KO2’s. It drove perfectly with no wobble of any kind.
I have had a full wheel alignment done so geometry should be spot on.
The new wheelset with the 235 tyres are now taken off and the car sitsbon standard 5,5” steelies and 195/80/15 factory tyres. With this weel configuration it drives just as smootly as when I picked it from the dealer sitting on the 215 BFG’s
The 235-tyre wheels have been balanced by the garage who did the liftkit, but I guess it would be worth while having a tyre specialist re-blanace them and check that both wheels and tyres are not faulty in any way.
Ot is however strange that the wobble is not conistent but comes and goes - iwhen it occurs, it is however always at 60-65 km/h.
Cheers
Lars
17 Nov 2024 20:05 #258365 by Lars Heede
Thank you very much for your input. I am right now standard 15” steelies with 195/80/80 standard tyres and the car drives smoothly with no wobble.
To the point of pressure, what would you reccomend?
