help with General Grabber AT2
  • dirtydogz
03 Dec 2010 18:27 - 03 Dec 2010 21:14 #6993 by dirtydogz
help with General Grabber AT2 was created by dirtydogz
GENERAL GRABBER AT2'S 205/75/15 OR 215/75/15
HAS ANY MEMBER USED THESE TYRES? WOULD LIKE FEED BACK PLS
THANX.BAZ
Last edit: 03 Dec 2010 21:14 by dirtydogz.
  • Nelson83
04 Dec 2010 15:56 #7017 by Nelson83
Replied by Nelson83 on topic Re: help with General Grabber AT2
I've got them fitted to mine :) They were reasonably priced from my then tyre fitters in Frome, Somerset (H+B tyres) - for 5 fitted and balanced on alloys they came out cheaper than almost all internet suppliers. I've had them on for just over 2 years (about 20-25k) and the back ones are almost like new, the fronts are due for replacement as the outside edge has worn more than the inside edge - a job for the new year.
On road they're fine, no road noise and plenty of grip.In the brown stuff they're fine for light laning etc, not comp/ extreme. In the current snow, they handle fine.
Like i said, my fronts are due for replacement at the begining on the new year, and i'll be replacing like for like. I'll try and post a few pics of the how much tread is left when it gets light tomoz
  • dirtydogz
04 Dec 2010 17:21 - 07 Dec 2010 17:28 #7027 by dirtydogz
Replied by dirtydogz on topic Re: help with General Grabber AT2
Thank you
For the information on the genral tyres,had some on my old sj410, 30 year a go so i'm happy they are still a good tyre.
BAZ
Last edit: 07 Dec 2010 17:28 by dirtydogz.
  • DAVE T
04 Dec 2010 18:38 - 04 Dec 2010 18:39 #7035 by DAVE T
Replied by DAVE T on topic Re: help with General Grabber AT2
i have had AT2S on mine for 30,000 miles now and there still heaps of tread and i have been in some nasty places with these, there a great tyre.
Last edit: 04 Dec 2010 18:39 by DAVE T.
  • mcjimny
07 Dec 2010 18:47 #7177 by mcjimny
Replied by mcjimny on topic Re: help with General Grabber AT2
To echo other replies, i've had some on for over 2 years now and i don't think there's a better value tyre for the jimny. BFG's will go on forever but will be at least double the price of the grabbers. Unless you want/need a really aggressive tread pattern i think they suit the jimny perfectly, i know people who lunch them on pickups and bigger trucks but they suit the lighter jimny.
The only time they really struggle is in deeeeep mud where they fill up with mud and won't clean quick enough.
If i wasn't after an aggressive tyre next time i'd have a full set in an instant but slightly wider.
  • Foxtrot
29 Dec 2010 12:27 #8285 by Foxtrot
Replied by Foxtrot on topic Re: help with General Grabber AT2
Hi, did the Grabbers fit ok as they are slightly taller at 205/75/15? my Jimny is standard with Duellers and I'm thinking about changing them out soon for some AT's due to them coming to the end of their life.
You may be ok with the wear on your tyres as long as they fit the discription below:
The current British legal limit for car tread depth is 1.6mm (across 75% of the tyre). However, most tyre experts advise that you replace your tyres when the tread is less than 3mm.
Thanks
