Rear wheel well lining?
- Thank you received: 1811
06 Nov 2023 13:11 - 06 Nov 2023 13:12 #251990
As we can see taking the bumper off reveals a horror story of epic proportions. OK it's just some mud and it washed off and when it's dry it will be waxoyl covered again. However I have the cheaper amazon mud flaps on both of them and I am wondering how to prevent this build up of muck. I know that there are some provisions for the plastic clips on the inner and outer flanges which makes me think suzuki might have done something about it for other markets but not the UK? Alternatively to a factory solution has anyone done something DIY that they are willing to let me plagiarise?
Rear wheel well lining? was created by Lambert
Last edit: 06 Nov 2023 13:12 by Lambert.
- Roger Fairclough
- Thank you received: 210
06 Nov 2023 15:18 #251994
by Roger Fairclough
Replied by Roger Fairclough on topic Rear wheel well lining?
You will never effectively stop it happening, so you need to consider how to prevent it from causing rust or corrosion. Personally I don't like mud-flaps because they just get plastered in mud and the constant flapping about destroys the fittings and promotes corrosion. You use Waxoyl and I use bitumastic paint along with a roofing mastic loaded with terylene fibres. I find this stuff to be strong yet flexible and lasts for years. This Summer I removed the rear bumper and applied the bitumastic to pristine paintwork. hopefully this treatment will keep it that way.
Roger
Roger
- Thank you received: 663
06 Nov 2023 16:25 #251996
Replied by jackonlyjack on topic Rear wheel well lining?
My 04 plate had rear bumper removed 7+ year's ago and all arches removed around 2 years ago
I know this look is not for everyone a mines only a toy
But I consider it in good condition
And so easy to clean
- Thank you received: 491
06 Nov 2023 18:03 #251997
Replied by DrRobin on topic Rear wheel well lining?
Last time I took my rear bumper off it looked similar to yours although not as bad. I cleaned it all out and treted the metal.
The bit that really worried me was the rubber flap shown in the first picture, just below the hanging bulb in your photo. This is all that stops water and mud from entering the rear of the car on the inside of the wheel arches. I expected to see a grommet to keep the water, mud and vermin out, but perhaps the bumper has a close enough seal with the plastic wheel arch to keep most things out?
Robin
Robin
The following user(s) said Thank You: jlines
06 Nov 2023 18:03 - 06 Nov 2023 18:06 #251998
by jlines
Replied by jlines on topic Rear wheel well lining?
My opinion of wheel arch linings & guards are that they just further trap dirt behind them so you may just be better off removing the bumpers once a year or so and retreating. Is the first time those bumpers have been off the car in its life? I guess the wet grass farm work your car does makes it all stick to the underside of the car. I went around a grass field in December last year and BigJimny was caked in mud stuck underneath the car which took several days to clean. More than you would get on a play day event.
Last edit: 06 Nov 2023 18:06 by jlines.
06 Nov 2023 18:06 #252000
Replied by Lambert on topic Rear wheel well lining?
I think permanent bumper removal is potentially one step too far. I was wondering about using rally style ones attached to the horizontal seam you can see in your picture and running it down against the bumper. That might help minimise which is all I'm bothered about. Neither of them are going to take first place in a concourse competition as they work for a living but equally having to strip the bumper off every time I wash the car will get old very quickly.
06 Nov 2023 18:15 #252001
That is spare jimny and 2 years of muck. Temeraire is tomorrow probably and I'm expecting much worse.
06 Nov 2023 18:52 #252003
Painted inside here Nov 2016
This is it now, not lifted the flap for years and mine goes in deep mud,dirty water
So you shouldn't worry yourselves to much
06 Nov 2023 19:38 #252006
by Busta
Replied by Busta on topic Rear wheel well lining?
The purpose of that flap is to release cabin pressure when you shut the doors. If you completely seal the cabin then it takes a surprisingly hard swing to shut the doors.The bit that really worried me was the rubber flap shown in the first picture, just below the hanging bulb in your photo. This is all that stops water and mud from entering the rear of the car on the inside of the wheel arches. I expected to see a grommet to keep the water, mud and vermin out, but perhaps the bumper has a close enough seal with the plastic wheel arch to keep most things out?
Robin
06 Nov 2023 21:20 #252007
Thanks for the explanation Busta, I wondered what the flap was there for.
Jackonly last time my bumper was off I did look under the flap and it was relatively clean inside yet filthy on the outside, so I guess it works and I am worrying too much.
Lambert what was yours like inside the flap?
Robin
Robin
06 Nov 2023 22:55 #252010
Replied by yakuza on topic Rear wheel well lining?
I bought an angled tip for my pressure washer. It was cheap for the karcher.
I can reach many nooks and crannies but still there is allways more danish mud..
07 Nov 2023 04:21 #252011
It wasn't too bad but in order to unplug the rear lights you have to take the loom bung out of the bottom so it got washed out anyway.
Robin
Time to create page: 0.170 seconds
