31” tyres, 2” lift, standard bumpers?
  • martinjsmith6
20 Apr 2023 19:34 #248731 by martinjsmith6
31” tyres, 2” lift, standard bumpers? was created by martinjsmith6
Hi all,
I’m relatively new here so hello!
I have stock Jimny currently running standard suspension with 215/75/15 Toyo AT’s. These are great tyres but I’d quite like a little more ground clearance and more mud plugging capabilities. I don’t want anything more than a 2” lift as I do daily the car for around 10 miles and I cannot be bothered faffing around changing brake hoses and stuff. I don’t mind doing a little bumper trimming within reason. What do you think is the max size tyres I can put on? I’m currently looking at either 235/75/15 which would give 1.2” lift which I’m not sure is quite enough or 31/10.5/15 which would give 3.3” lift.
21 Apr 2023 03:26 #248732 by Lambert
Anything bigger than the 215 you have now is going to need a regear of some description as you will quickly burn up either the clutch or the transmission fluid. Not saying it can't be done just that it's not as simple as fitting the tyres under the car.
21 Apr 2023 13:12 #248737 by yakuza
My clutch is smelly also with the 235 and low gears. It holds but will be changed. And 235 without more engine or gearing will make a dull car. 31 would need major cutting of the fenders and bumper to clear.
All this based on my own experience.
21 Apr 2023 13:31 #248738 by saxj
Hi all,
You don't say which model Jimny you have.
On a gen 3, 235's don't fit with a 2" lift. You need to some cutting.
On a gen 4, 235's just fit with a 2" lift with a little trimming of the front bumper.
21 Apr 2023 16:42 - 21 Apr 2023 16:46 #248743 by yakuza
If you accept minor rubbing on full flex 235 is ok on stock wheels. No cutting. Yes the stock wheels are too narrow so in some peoples book it is not ok. But for me it works fine.
Edit: and no mud flaps.
Last edit: 21 Apr 2023 16:46 by yakuza.
  • martinjsmith6
22 Apr 2023 20:45 - 22 Apr 2023 20:46 #248767 by martinjsmith6
Replied by martinjsmith6 on topic 31” tyres, 2” lift, standard bumpers?
Sorry forgot to add that bit! It’s a Gen 3 Automatic.
Last edit: 22 Apr 2023 20:46 by martinjsmith6.
