Tyre Pressures
17 Apr 2023 16:25 #248657
by madman
Man of many machines small and large , 2001 Kap Jimny and 2023 LCV 2" lift and very happy.
Tyre Pressures was created by madman
Hi everyone
I running my Jimny on 215/75/15 B F Goodrich T/A KO 2 All Terrain 97S tyres , can anyone suggest what pressure suits these for road use.
Many thanks
Ken.
Many thanks
Ken.
- Jonesie
17 Apr 2023 18:47 #248663
by Jonesie
Replied by Jonesie on topic Tyre Pressures
Running 28psi in mine ….
Jonesie
Jonesie
- Thank you received: 1991
17 Apr 2023 19:04 #248665
Replied by Lambert on topic Tyre Pressures
You can calculate the actual PSI using the maximum load/maximum inflation information embossed on the side of the tyre and the axle weight on the main vin plate. It will probably be in the low 20s psi. My 97 load index all terrain work out at 21 which looks about right from experience unfortunately I have tpms and it gets very upset with me if I run that low even though it improves the ride quality.
18 Apr 2023 08:20 #248681
by madman
Replied by madman on topic Tyre Pressures
Much appreciated Jonesie.
18 Apr 2023 08:22 #248682
by madman
Thank you, will give it a go but as you say tpms is a bit moody when you go that low. however very useful and noted.
Cheers Ken.
Cheers Ken.
18 Apr 2023 15:05 #248692
by fordem
Replied by fordem on topic Tyre Pressures
The goal here is presumably to get the pressure correct for best tire life, and if that is the case, it is not going to be determined purely by the tire's load rating & pressure, rim/tire width and vehicle loading are also factors to be considered.
Start with the recommended pressures and adjust using the chalk method.
Find a quiet stretch of straight road, and using the chalk, mark a wide band across the full width of the tread on each tire, drive the vehicle in a straight line for a short distance and then take a look at the chalk marks to see where the chalk has rubbed away....
If it's the middle of the tread, the tire is "crowning", either because the pressure is too high or the tire too wide for the rim, if it's both inner & outer edges of the tread, either the pressure is too low or the rim too wide, if it's one edge, either inner or outer, you have some sort of alignment or suspension issue.
Adjust the pressure up or down to get even "wear" or displacement of the chalk.
I suspect you'll find the pressure using the "chalk method" very close to Suzuki's recommended pressures.
The following user(s) said Thank You: madman
