Roof tents on a Gen 3 ?
18 Nov 2022 11:18 #245985
by kfrogzx7
Roof tents on a Gen 3 ? was created by kfrogzx7
Has anyone any experience of mounting a roof tent onto a Gen 3 ? I'm planning a couple of long trips ( not quite "expeditions"
) and am looking at the Tentbox options particularly. I'd welcome any advice please.
I'm also particularly concerned re the recommended roof load capacity, which my manual says is only 30 kg ( !!! ??? ), that'd make even the lightest roof tent ( 50 kg ish ) impossible !!
18 Nov 2022 11:21 #245986
by kfrogzx7
Replied by kfrogzx7 on topic Roof tents on a Gen 3 ?
PS Is the roof load capacity significantly greater on the Gen 4 because I've seen plenty of youtube overlanders with Gen 4 roof tents ?
- Thank you received: 1999
18 Nov 2022 16:03 #245994
Replied by Lambert on topic Roof tents on a Gen 3 ?
30 kg is correct. For both. I have cross bars instead of the factory rails bolted directly to the roof and whilst doubtless capable of taking the weight I am still limited by the factory limit because over that and the police and insurance are not going to be happy if something untoward happened. The other issue is I have a roof box and it costs me something like 4mpg. Also also on my farm I have over loaded the roof as needs must and it has a very dramatic effect on the stability, I wouldn't like it on the road, far too wobbly.
- Thank you received: 667
18 Nov 2022 16:27 #245995
Replied by DrRobin on topic Roof tents on a Gen 3 ?
Member 'Reason 2 Doubt' (aka Stuart) had a roof mounted tent on his Jimny, he took it on a long trip from the UK to Italy, see the photos here
www.lines-associates.com/piwigo/index.php?/category/677
Unfortunately Stuart sold his Jimny earlier this year, so he might not be on the forum now, but if you look at the photos you might get an idea of what he did and the following post has a few more details.
www.bigjimny.com/index.php/forum/6-jimny...tent?start=12#226831
18 Nov 2022 19:08 #245998
by kfrogzx7
I'm frankly astonished by the 30 kg limit, all roof racks would be more than that before you put anything on them !!
Are we saying that most people ignore the weight limit then, because Reason2Doubt's tent and rack would be way over the limit as would all these youtube overlanders ?
18 Nov 2022 21:27 - 18 Nov 2022 21:29 #246003
Replied by Soeley on topic Roof tents on a Gen 3 ?
The Jimny itself can take the weight and more when stationary. It is the dynamic load when you get moving is the limiting factor.
Also just because lots of people are fitting them doesn't make it right. I think I worked it out for the Gen4 with the Front Runner full roof rack you could the only strap a 5kg load to it, as that weighs about 25kg.
The real issue is if you happen to roll it on the road, your insurance will be void.
As long as you know the limitations/risks/possible consequences, it is your choice at the end of the day.
Last edit: 18 Nov 2022 21:29 by Soeley.
Time to create page: 0.217 seconds
