Gen 4 Jimny observations
03 Nov 2022 08:16 - 03 Nov 2022 18:24 #245725 by lightning
We've owned our 2020 Jimny two years and had no issues with it at all.
The vehicle has lived outside and done 11,000 miles.
This is l realise normal for new vehicles, they are generally pretty good nowadays.
What's impressed me about the Jimny however, is the way it's been put together. l had to take all the interior and exterior trim off to get a dent removed from the rear corner, also the same to fit the tow bar and rear speakers.
l managed to do this without breaking one clip or fastener. All the parts came off and went back on with no broken clips, although the outer wheel arch trim needed the clips releasing from inside the panel.
My friend has one of the new Defenders, a great vehicle but when he came to fit side steps almost every clip and fastener broke off the sill trims and other parts when he removed them.
Okay they were replaceable but l think this is poor design.
Also, in years to come when these plastic parts are no longer available it's going to be an issue.
Last edit: 03 Nov 2022 18:24 by lightning.
03 Nov 2022 11:22 #245734 by Lambert
Replied by Lambert on topic Gen 4 Jimny observations
Yeah. You get in a Jimny, use it and put it away. You go to get a defender and have to set to and fix it then fix it again half way through the job and then you fix it when you are done in the vain hope you might get away with not needing to fix it before you use it again. Been there done that.
03 Nov 2022 18:26 - 03 Nov 2022 18:28 #245744 by lightning
Replied by lightning on topic Gen 4 Jimny observations
You've had one of the new Defenders? l am talking about the 2021 onwards version.
I've got one of the old Defenders. It's a 2005 110, done 85,000 miles in my ownership (146,000 altogether) and does need looking after, although it's only actually broken down once.
Last edit: 03 Nov 2022 18:28 by lightning.
03 Nov 2022 19:14 #245747 by 300bhpton
Replied by 300bhpton on topic Gen 4 Jimny observations
I think the old ones probably get a bad rap unfairly. I have a 1989 Ninety parked on the drive with 152,000 miles. Most of the broken interior bits are due to human error and abuse. The basic design isn't bad at all really. I had to remove some rear trim to feed in a CB aerial cable earlier in the year. I did break a clip, but it mostly came out and went back none the worse for wear. The clip was plastic and is 33 years old, so I can't really complain.
The vehicle has lived most (or maybe all) of its life outside. Doesn't seem to have been loved much, not in the past few decades. But it is pleasant to ride in and drive still.
I do like the mod cons of the Jimny though
04 Nov 2022 04:43 #245754 by Lambert
I have a number of friends in the industry that have either long or short ones and they all say the same thing, it's ok if you have another vehicle and the land rover is under warranty. Now these are primarily working vehicles and that makes a difference I'm sure but still. It's why I went for the Toyota.
04 Nov 2022 08:02 #245759 by 300bhpton
Newer ones maybe you'd be right. Older ones I've found to generally be quite robust. As in, they'll nearly always get you home. They might always have some niggles. But fundamentally rather solid.
I may be a little biased as I've been around Land Rover's all my life. As an extended family I think we have had in the region of 70 Land Rover's over the years.
Even now between far few of us we somehow own 15+ Land Rover products. Newest being an L450 Range Rover, but most hailing from the 80s and 90s.
