New coil springs?!
- ow3x3xpr3ss
13 Jun 2021 00:32 - 13 Jun 2021 00:36 #235751
by ow3x3xpr3ss
New coil springs?! was created by ow3x3xpr3ss
Hi all,just a quick and simple question, I will gain back some lift and improved handling on road with a complete set of new coil springs?! for my 17 years old Jimny.
Cheers
Is already fitted with new shock absorbers, which made a huge difference...
Cheers
Last edit: 13 Jun 2021 00:36 by ow3x3xpr3ss.
13 Jun 2021 07:56 - 13 Jun 2021 07:59 #235752
by Scimike
Replied by Scimike on topic New coil springs?!
The direct answer is yes - after 17 years it's likely your original springs have dropped a little. Fitting new should restore this.
will it feel any better? - subjective at best. It will feel different, better or worse is your perception. Dampers are the item that can change the feel the most and you have already swapped these.
I assumed you are staying OEM spring length and not referring to a "lift" by adding longer springs. If you are be aware that the spring travel is usually matched to the damper travel.
Last edit: 13 Jun 2021 07:59 by Scimike.
- Thank you received: 1983
13 Jun 2021 08:25 #235753
Replied by Lambert on topic New coil springs?!
I used suplex standard height springs to recondition Dreadnaught, made a definite improvement on the 80k original ones.
- ow3x3xpr3ss
13 Jun 2021 08:54 #235756
by ow3x3xpr3ss
Replied by ow3x3xpr3ss on topic New coil springs?!
Yes ,I'm going for the standard ones ,not intrested in any modifications, 97% of the time is used on tarmac. I reckon is not to difficult to install them myself?! Thank you
Cheers
Cheers
13 Jun 2021 14:43 #235763
by Scimike
You can't beat a recommendation, the suplex Lambert fitted would be my first choice. Its simply that a lot of "monkey metal" springs are in circulation, they don't last very long before you are sagging again, at least they are in the Land Rover world.
It appears to be a simple job although I have not done it myself. My perception is that you can change them without spring compressors if you uncouple the damper and lift the body / lower the axle, enough space exists to get them out. Those that have done the job please confirm or correct me.
All the bestMike
All the bestMike
13 Jun 2021 16:06 #235765
Yes easy just undo the bottom of the dampers and support the body, the axle drops enough to get the springs out.
