Gearstick vibration - how much is normal?
16 Apr 2021 14:23 #234507 by slickfonzy
Hi all,
I picked up a 2013 Jimny (23,000 miles) in December, the first Jimny I've owned.  There's some vibration through the gearstick (most noticeable at idle), nothing bone-shaking but still moderate.  Is some vibration normal for a Jimny?  It's not something I've noticed on any car I've owned before, but wondered if it's one of the peculiarties of the Jimny.  I've checked the transfer box mounts and rear engine mount, there's a very small amount of play (presumably a small amount in the rubber is normal?) but nothing excessive.
Any thoughts most welcome!
Ian
  • justintime441
16 Apr 2021 15:09 #234508 by justintime441
Replied by justintime441 on topic Gearstick vibration - how much is normal?
light vibration is normal.. if you can, jack the engine up slightly and see if the vibration is reduced
16 Apr 2021 15:28 #234509 by jackonlyjack
When checking rear engine gearbox mount did you jack up the gearbox ?
These can delaminate and being a V shape can look in good condition
at a glance and giving it a wiggle
Only way is jack up the box see if it separates
The following user(s) said Thank You: slickfonzy
16 Apr 2021 20:00 #234511 by Scimike
I can't actually say that I have noticed any vibration at all from the gearstick in the years I have owned our Jimmy.
Is it a visual or audible vibrate, or both?
I'll start mine tomorrow (it's dark now) and take a look, maybe drop a video if I still think it's vibration free.
16 Apr 2021 21:06 #234519 by slickfonzy
Thanks all for your replies.  I didn't jack up the gearbox when looking at the rear engine mount, I'll do that and see what I find.  There is a visible shaking of the gearstick at idle, but it's the feel that's especially noticeable.  I'll take a video in the daylight on Sunday and pop a link on here.
16 Apr 2021 21:35 - 16 Apr 2021 21:37 #234520 by DrRobin
My 2011 gear stick vibrates a little bit, you can’t hear it or really see it, but if you put your hand on it you can feel it.
Still it is not surprising, a long rod connected to the engine, it would be a miracle if it didn’t vibrate a little.
If it is bad enough to jump out of gear then that would be something else.
Robin
Last edit: 16 Apr 2021 21:37 by DrRobin.
Time to create page: 0.192 seconds
