CB and other comms
- Thank you received: 1939
09 Sep 2020 10:45 #227982
CB and other comms was created by Lambert
So I dug out my ancient midland cb again in optimistic readiness of the meet and it let the smoke out in a big way. What can people recommend for simple limited use but still with some durability. Probably thinking hand held with a card kit or something that will take my existing springer? Cheers in advance.
09 Sep 2020 14:18 #227989
by 300bhpton
Replied by 300bhpton on topic CB and other comms
Is it definitely a CB you are after? I'm starting to move to PMR446 these days. Decent handhelds of these can be had for £17-25 delivered. Handheld CB's alway looks pricey to me.
Have bought from these guys in the past:
www.thunderpole.co.uk/cb-radio.html
www.kcb.co.uk/
www.kcb.co.uk/
The following user(s) said Thank You: TillymintDLG
09 Sep 2020 14:50 #227991
Replied by mlines on topic CB and other comms
Handheld "traditional" CBs are expensive in my opinion. PMR446 range from toys to business class. My sons marina use Motorola business PMR446 and in general use in a fairly open area with some metal sheds they max out at 500 metres. We have used similar within wooded areas and at 2-300 metres they drop out. Business class ones are quite robust and have good battery life.
Traditional mobiles are fairly cheap although there is always a debate as to whether to use UK or EU channels.I have had more success with these in terms of distance, they cover off-road sites well, the downside is that they are attached to the car!
I will be on traditional CB at the meet and could have PMR446, 2metres, 70cms and DMR if useful
de G1SEO
de G1SEO
09 Sep 2020 15:13 #227992
by 300bhpton
I'm seriously thinking about fitting a PMR set to my Jimny.
Currently using some Chinese handheld ham radios (Baofeng UV-5R) configured to the PMR446 channels and with the output power dialled down.
Using one of these and a Walkie-talkie style 2nd handset I've clocked 0.5 miles with clear 2 way communication. Both handsets where outside of vehicles however.
Using two of the UV-5R's in vehicles, best I've clocked is 0.9 miles going across a town and lots of buildings. I think an external aerial would help a lot. Also tested my CB on the same section and managed 1.4 miles, but slightly less clear overall, fitted with a Thunderpole Orbiter (1.55m) aerial.
09 Sep 2020 15:23 #227994
Thing is that the UV5-R are more powerful even when dialled down (1 watt) than PMR446 (0.5watt) and the aerial can have more gain so its not surprising they have better range.
The following user(s) said Thank You: Lambert, TillymintDLG
09 Sep 2020 16:29 #227998
Replied by Soeley on topic CB and other comms
I have
THIS
comes with the car kit.
Time to create page: 0.433 seconds
