Air inlet for ventilation/heater
05 Sep 2020 12:00 #227762 by Soeley
Does any know where the air inlet is on the Gen4 for the heating/cooling vents?
When laning and is slow traffic, with the heater set to low the air coming through the vents is warmer than the ambient air outside. But when you get going again it is a nice cool breeze. So I'm guessing it is under the bonnet somewhere and the engine heat is warming the air up, or it is ducted close to a heat source.
Wondering if it can be ducted from behind the grille, even if only for summer time?
05 Sep 2020 12:38 #227763 by mlines
This vent seems to align with the intake on the heater unit
05 Sep 2020 13:42 #227767 by Soeley
I did wonder about that one, not yet had reason to remove the scuttle panel :) It must just be getting hot through the bulkhead maybe and maybe drawing hot air from the bonnet?
  • GeorgeC
05 Sep 2020 15:48 - 05 Sep 2020 15:54 #227771 by GeorgeC
Replied by GeorgeC on topic Air inlet for ventilation/heater
I guess you have tried "Re-circulate" as it may be cooler than "Fresh"? And the temp setting?
I normally use "Fresh, 30C, Fan 1-3" and now "OFF"! :unsure:
Last edit: 05 Sep 2020 15:54 by GeorgeC.
05 Sep 2020 15:55 #227772 by Soeley
mlines wrote: This vent seems to align with the intake on the heater unit
You were right Martin, just tested with some tissue and it sucked it down when fan blower turned on.
05 Sep 2020 15:57 #227773 by Soeley
GeorgeC wrote: I guess you have tried "Re-circulate" as it may be cooler than "Fresh"? And the temp setting?
Recirculate will just reuse the already warm air within the cab. My point was on low or cold the air temp should be the same as the outside. Looks like it is either dragging heat from the bonnet surface or through the bulkhead.
Time to create page: 0.147 seconds
