Gearbox level / filler plug removal
- RogersJimmy
24 Mar 2019 13:06 #205002
by RogersJimmy
Gearbox level / filler plug removal was created by RogersJimmy
2001 Jimny
Try as I might, I cannot shift this plug to check the oil level. I have owned the car for a few months and have no idea when it was last checked so think it is a good idea to know.
How do others overcome this problem? I have a proper metric square tool that I got to do the axle plugs, but getting a leverage on it is difficult in the location of the plug.
I have even thought about making a hole in the transmission tunnel to get at it!
Any advice gratefully received before I get drastic!
Cheers.
Cheers.
24 Mar 2019 18:41 #205008
Replied by jackonlyjack on topic Gearbox level / filler plug removal
My square drive has a 17mm body to take spanner or socket
So i just slide scaffold tube over the spanner for extra leverage
I also have 4 ramps select 4wd low and drive up for easier access
The following user(s) said Thank You: RogersJimmy
24 Mar 2019 22:25 #205025
by Velocette
Replied by Velocette on topic Gearbox level / filler plug removal
Just did mine yesterday. Used a 17mm ring spanner on the square drive body and hooked a foot long piece of tube over the end to extend it. Use a flat Snap On spanner to get up the narrow gap between bulkhead and the filler plug. I also ran the car for a few miles first to warm up the gearbox housing a little. The best part was using one of those syphoning oil pumps off e-bay to refill the box. No struggling or spillage whatsoever !
- RogersJimmy
25 Mar 2019 08:53 #205034
by RogersJimmy
Replied by RogersJimmy on topic Gearbox level / filler plug removal
Thanks for helpful replies.
Velocette, please could you post the link to the eBay pump you have as there are several types on there.
And do you have a Velo? Perhaps an LE with that intriguing hand gear change?
25 Mar 2019 09:43 #205035
by Velocette
No eBay APP ID and/or Cert ID defined in Kunena configurationThis is the one,,
Not an LE I'm afraid,,,a 1966 500 Venom Clubman .
- RogersJimmy
25 Mar 2019 09:54 #205037
by RogersJimmy
Thanks Velocette,
I have ordered one and can see 101 uses for it in my garage.
Think I would rather have your Venom than an LE any day. I remember the police using grey LEs in the 60s. We called them Noddy Bikes!
Cheers.
Cheers.
Time to create page: 0.154 seconds
