Heater problems
  • Ijmclees
24 Nov 2018 12:50 #198095 by Ijmclees
Heater problems was created by Ijmclees
Hi all,
Looking for advice, I’ve got 2002 Jimny the heater is hardly blowing any hot air the top hose seems to warming up but not the bottom one also when I removed the rad cap the water looked brownish.
24 Nov 2018 18:14 - 24 Nov 2018 18:16 #198110 by Max Headroom
Replied by Max Headroom on topic Heater problems
I'd have said that sounds like the thermostat has stuck open allowing fluid to circulate without allowing it to fully heat up.
If your coolant looks like rusty water theres also a chance the heater matrix is clogging up which won't help.
I changed ALL fluids on my car when I first got it, including the coolant which just looked like minging blackish water
Last edit: 24 Nov 2018 18:16 by Max Headroom.
  • MadsV
24 Nov 2018 18:57 #198114 by MadsV
Replied by MadsV on topic Heater problems
Change the thermostat. The brown water could come from a rusty thermostat aswell. Someone could have had pure water on it
25 Nov 2018 16:39 #198146 by Delux
Replied by Delux on topic Heater problems
Rusty water in your cooling system means oxygen is in there.
Could just be lack of maintenance, where oxygen gets in over time.
Could be a leak.
I would have a look around the engine, radiator and below the centre of the dash for signs of rusty water indicating a leak.
I would top up the radiator, turn off the heater fan but set the temp to hot. Then I'd leave it running until the temp gauge showed half way. Thats when your thermostat should start opening. When it gets there the heater fan should blow hot air when you turn it on.
If you want to check the thermostat, wait until the engine is cold, remove the thermostat. Boil the kettle, drop the thermostat into a mug of boiling water and you should see it open. Best not to use your own mug but I work in a garage so there are plenty of mugs there!
Busiest Mechanic in Scotland!
My pics (inc. pics of my latest Jimny project)...
www.flickr.com/photos/159422664@N08/albums
My ebay stuff for sale...
www.ebay.co.uk/usr/deeelux
25 Nov 2018 19:16 #198156 by Max Headroom
Delux wrote: I work in a garage so there are plenty of mugs there!
heheh - its exactly like that where I work, too :laugh: :laugh:
26 Nov 2018 16:58 - 26 Nov 2018 18:10 #198184 by kirkynut
Replied by kirkynut on topic Heater problems
If you're going to remove the thermostat to test it, you may aswell put a new one in.
It does sound like a stuck thermostat but the radiator sounds grim. They're not expensive, so I'd change both and flush the coolant out with a hose.
Last edit: 26 Nov 2018 18:10 by kirkynut.
