Broken front n/s coil spring on 4year old Jimny
- Lenz
22 Sep 2018 18:31 #196209
by Lenz
Broken front n/s coil spring on 4year old Jimny was created by Lenz
On the way to its second MoT I heard a clang from underneath but nothing untoward happened so I carried on to the garage where the test revealed a broken coil spring. Replaced both coil springs on the advice of the garage.
This vehicle had not been off road and is relatively low mileage and as far as I recall has never hit a really bad pothole so why did the spring break?
The garage seemed to think that broken coil springs are not uncommon. I would have thought that coil springs are pretty robust and would only break if subjected to very harsh treatment or if the steel had a manufacturing flaw. Anyone have a view on why my spring should have broken?
Mike
Mike
22 Sep 2018 19:24 #196212
by Scimike
Replied by Scimike on topic Broken front n/s coil spring on 4year old Jimny
Not got any views on the Jimny coil springs, mine is a 2009 and still on originals, but it does appear to be a modern car "thing" along with ignition coil packs. In the good old days your single coil and springs lasted the life of the vehicle. That said old cars rusted through in a few years, so thats no recommendation :laugh:
Vauxhall Corsa D's eat rear and front coil springs, common issue, also coil packs. They can fail in a few years, "monkey metal" from China could be the main issue.
No big deal, just change them.
The following user(s) said Thank You: Lenz
- Thank you received: 1999
22 Sep 2018 20:03 #196215
Replied by Lambert on topic Broken front n/s coil spring on 4year old Jimny
Our old c class Mercedes chewed coils for fun, like said above its not uncommon and if the heat treatment is only slightly off a spring can be soft and sag or hard and snap, it's easy to get wrong.
- Lenz
23 Sep 2018 18:04 #196227
by Lenz
Replied by Lenz on topic Broken front n/s coil spring on 4year old Jimny
Thanks for the responses. Looks like the garage were right then.
Mike
Mike
- mickt
23 Sep 2018 18:21 #196229
by mickt
Replied by mickt on topic Broken front n/s coil spring on 4year old Jimny
The state of the roads does not help. Springs for road cars are designed for flat roads not the pockmarked ones we have to use on a daily basis. Constant hammering, be they minor, adds up.
02 Jul 2024 12:30 #256595
by Buzz
Replied by Buzz on topic Broken front n/s coil spring on 4year old Jimny
Resurrecting old thread - my 7 year old Jimny has just had its second OSF spring break. My daughter’s Jimny also had OSF spring break last year at 7 YO. Both cars low mileage and used daily around town and not seen off road. At this rate I’ll be best bulk buying springs for future consumption!
Buzz
Buzz
Time to create page: 0.211 seconds
