Help with bypassing the vacum system.
- gazert
23 Nov 2010 19:21 - 23 Nov 2010 19:34 #6378
by gazert
Help with bypassing the vacum system. was created by gazert
I need some expert help from my more knowledgable jimny pals,
I have replaced the vacum hubs with AVM manual freehubs.
I knew this would make the green light on the dash flash.
As I have the push button 4L system I now have to fool the system into thinking that the vacum hubs are engaged.
Can I re route the vacum pipes to fool the sensor or is the little vacum switch with the filter able to be shorted to fool the sensors?
Help please.
Ta in advance,
Gaz
Sorry I should have put this in tech.
If anyone can move it to tech please do so.
Help please.
Ta in advance,
Gaz
Last edit: 23 Nov 2010 19:34 by gazert.
- JimBru
23 Nov 2010 19:43 #6379
by JimBru
Replied by JimBru on topic Re: Help with bypassing the vacum system.
just block the pipes that come away from the vacum solinoids, thats all I have done. I put a nicely fitting screw into the tubes and taped them up.
- gazert
23 Nov 2010 19:46 #6380
by gazert
Replied by gazert on topic Re: Help with bypassing the vacum system.
Do you have the push button 4L system?
- JimBru
24 Nov 2010 08:18 #6395
by JimBru
no mate the stick type system, I thought they all worked in the same way? apologies if they don't
- 4wheelers
24 Nov 2010 09:21 #6397
by 4wheelers
Replied by 4wheelers on topic Re: Help with bypassing the vacum system.
I have the push button 4wd selector. The solinoids and pipes are the same as the models with selector stick. Block the pipes at the main solinoid on the drivers side under the bonnet and all your flashing light problems will go away. Jamie showed me what to do as his is the same set up. Two screws are all you need to block the flexible pipes. I think they are about M5.gazert wrote: Do you have the push button 4L system?
- oxford_bloke
24 Nov 2010 13:52 #6403
by oxford_bloke
Replied by oxford_bloke on topic Re: Help with bypassing the vacum system.
can you not get into the dashboard console and remove the bulb? then you can remove all the unwanted bits.
tom
tom
Time to create page: 0.226 seconds
