Number plate bulb replacement - how to?
23 Nov 2015 11:57 #157012
by Brucester
Number plate bulb replacement - how to? was created by Brucester
Probably straight forward but my hands went numb yesterday trying to figure out how to change the bulbs in the number plate fittings. Any ideas much appreciated.
23 Nov 2015 12:11 #157013
Replied by Daniel30 on topic Number plate bulb replacement - how to?
They twist off but get clogged up with dirt/dust mine were very stiff keep applying soapy water see if it moves
23 Nov 2015 12:40 #157014
by Busta
Replied by Busta on topic Number plate bulb replacement - how to?
As Daniel says, just a simple twist but they are always ridiculously stiff and slightly awkward to grip! Maybe try very gently with some water pump pliers.
23 Nov 2015 12:48 #157016
by Brucester
Replied by Brucester on topic Number plate bulb replacement - how to?
Ah thanks peeps, so i was trying the right way then, just a bit stiff i suppose so will try your suggestions. I assume it's just the clear plastic dome that twists off and presumably it's anti-clockwise? I'll be putting LED's in so wont need to take them off again with any luck.
23 Nov 2015 12:51 #157018
by Busta
Yes and yes.
23 Nov 2015 13:03 #157020
Test them before you put the covers back on I find some of the led's connection are a bit iffy
Time to create page: 0.380 seconds
