Spring spacers, yey or ney
  • JimBru
16 Oct 2010 17:56 #5200 by JimBru
Spring spacers, yey or ney was created by JimBru
No eBay APP ID and/or Cert ID defined in Kunena configurationWhats people's thoughts on these spring spacers then? I might give them a try if my new tyres are scrubbing, recommended?
Cheers
Bru
16 Oct 2010 22:51 #5214 by Garry
ive never used or tried them so cant really give a good opinion on them,
however, a chap i knew had them on his jimny to stop scrubbing tires, they did that, but also stiffend up the suspension so hard he could go round corners on 3 wheels.
17 Oct 2010 11:03 - 17 Oct 2010 11:13 #5216 by dirtydogz
Attachment DSCF1153.JPG not found
I HAVE FITTED BITS4VITS 1.5 INCH SPRING SPACRES TO MY JIMNY A LITTLE BIT MORE EXPENSIVE BUT CUT TO FIT THE SPRINGS.RIDE IS OK.BAZ.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 17 Oct 2010 11:13 by dirtydogz.
  • JimBru
17 Oct 2010 16:47 #5223 by JimBru
Replied by JimBru on topic Re: Spring spacers, yey or ney
thanks for the reply, i'll see how the tyres fit, if they are scrubbing i'll have a look at the bits4vits ones
21 Oct 2010 19:23 #5286 by DVF
Replied by DVF on topic Re: Spring spacers, yey or ney
I've just fitted the Bits4Vits ones a couple of weeks ago. Since they are cut to shape they effectively remove most of one coil of spring which stiffens them a bit, more than I was expecting anyway. The ones you were looking at won't do this. Apart from that there won't be much, if any, difference.
21 Oct 2010 21:36 #5287 by mcjimny
I'm also interested in this, how does it affect your articulation as it stiffens them up? Also does anyone running them top out the standard shocks? Just trying to weigh them up against a lift kit - which i would have to wait a few more months for.
Time to create page: 0.271 seconds
