Towbars for recovery?
  • jonesyba420
06 Sep 2013 17:46 - 06 Sep 2013 18:01 #82370 by jonesyba420
Towbars for recovery? was created by jonesyba420
So I know alot of people use towbars as a rear recovery point so ive been looking at a few to use as a recovery point but they alll seem to have a lower towing capacity than the weight of the car! and considering that when your stuck fast the load could be double or more surely this is not a good option really?!
so what are your views and what towbars are people using for recovery?
Last edit: 06 Sep 2013 18:01 by jonesyba420.
  • Teds Jimny
06 Sep 2013 19:39 #82385 by Teds Jimny
Replied by Teds Jimny on topic Towbars for recovery?
I bought one off ebay for £100 and it came with a standard ball hitch, however you shouldn't really tow off the bull hitch with a rope as it could fly off, so I bought a ball and clevis type hitch for about £15 which has a proper verticle fixing point which is great for fixing a rope too.
  • jonesyba420
06 Sep 2013 19:42 #82386 by jonesyba420
Replied by jonesyba420 on topic Towbars for recovery?
What towing capacity does the tow bar have, the max ive found is 1300kg which is less than the car weighs? Does it attach to the shite tie down points?
06 Sep 2013 20:06 - 06 Sep 2013 20:45 #82388 by Halford
Replied by Halford on topic Towbars for recovery?
IMO it looks like all tow bars attach pretty solidly to the chassis, so can't see there being any issues with strength
only downside I can see is that you'll loose some rear ground clearance, but then again a tow-bar can act as protection when "dropping off" rocks, pleased I had mine to protect my S/S rear box :ohmy: I heard mine ground a few times when I was out, and Gaz saw it catch in his role as gate closer ;)
downside is that initially, everytime you put the groceries in the "boot", you smash your shins :pinch: but you soon wise up :whistle:
Last edit: 06 Sep 2013 20:45 by Halford.
  • jonesyba420
07 Sep 2013 05:50 #82409 by jonesyba420
So even tho most tow bars seem to have a max towing capzcity of 1300kg it doesnt matter? Has anyone ripped their tow bar off from a sticky recovery?
  • Teds Jimny
07 Sep 2013 09:18 #82417 by Teds Jimny
Yer it doesn't matter really, and like halford said it does lower ground clearance, however I've found that my towbar just slices through the ground with the weight of the car, so actually it doesn't really reduce the ground clearance, as it digs beneath the surface, either way, you won't snap or brake one.
Time to create page: 0.416 seconds
