Possible change to the way we sell T-Case kits...
- g187eev
- Visitor
The customer would have the coice to either :
- swallow the cost and not return their Jimny t-gase gear.
- Remove and return the gear from the jimny box, and receive £50 back by cheque/refund to card.
- Return the gear and receive a free ORA goodie to the value of £50
Any thoughts?
RB
Is it not possible to just remove the pick up ring from the Jimny box and use it in the sj box? This is what I did when I bought my rocklobster from you a couple of years ago. Surely this would be simpler and save the expense of transporting the ring backwards and forwards. It was a simple matter to press the ring onto the flange.
Peter
- g187eev
- Visitor
Not sure whats happened with your kit, maybe you picked up a box which already had a modified/re-manufactured speedo ring on it?
The ID and thickness of the factory Jimny ring and the dimensions it needs to be a totally different...
postage for this part would only be 2/3 pounds...
RB
- supergaz
- Visitor
The Jimny transfer box will become redundant and isn't worth anything, so even though in good condition, it would probs just be skipped.
Awful getting old!
- g187eev
- Visitor
The only thing that is useful in there is the speed'o gear. Which is where this plan comes in to play.
RB
- supergaz
- Visitor
SJ boxes are getting very hard to get hold of.
I think a trade in will be the best option, this will help our credit cards after buying goodies
- Gromit
- Visitor
- supergaz
- Visitor
Gromit wrote: Where are all these cheap transfer boxes on Ebay ?, I need one and the cheapest is £75 !!!!
I'm going to remove mine shortly! As I am going to fit a SJ box, Has got KAP heavy duty mounts! Sure we could sort something out, I pass your area a'lot so could drop off
- Gromit
- Visitor
Would you take £50 for it ?
- supergaz
- Visitor
I have bent the stick with heat to suit a 2"body lift, just then bungee tied it back as It jumped out once, needs slightly more bending. I can pop it out this weekend if you want.
PM sent.
- aniesigh
- Visitor
