Fitted new light pod
  • myers647
  • Visitor
  • Visitor
18 Sep 2011 13:21 #22076 by myers647
Fitted new light pod was created by myers647
:cheer:
Hi all just thought I
would post a of picture of the light pod iv fitted today. I got it at a bargain price of £31.
cheers
18 Sep 2011 14:51 - 18 Sep 2011 15:06 #22079 by dirtydogz
Replied by dirtydogz on topic Re: Fitted new light pod
Look good on the hard top conversion B)
Attachment photo1.JPG not found
Hope you don't mind me adding the photo.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 18 Sep 2011 15:06 by dirtydogz.
  • Fearghal Murphy
  • Visitor
  • Visitor
18 Sep 2011 15:39 #22083 by Fearghal Murphy
Replied by Fearghal Murphy on topic Re: Fitted new light pod
Looks great !! Great looking fit !! Have you any links for these bits or even a good site where these type parts can be found?? there is F**K all over here in Ireland really !! Good work !!
18 Sep 2011 16:01 #22092 by dirtydogz
EBAY
Linkhttp://www.ebay.co.uk/itm/Roof-Top-Light-4x4-SUV-Jeep-CRV-Black-Bar-White-Lens-JB-/110528130398?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19bbfd6d5e#ht_770wt_754
  • myers647
  • Visitor
  • Visitor
18 Sep 2011 17:44 #22102 by myers647
Replied by myers647 on topic Re: Fitted new light pod
hi mate thanks i think it looks good.Il be using this when i go shooting. it was very easy to fit apart from i have drilled a small hole in the hard top for the wires to go through, im not sure weather this was a good idea as these roofs are probably worth as much as the car is its self. This is were you can get a Light pod from.
www.direct4x4.co.uk/p-575-abs-spotlight-pod.aspx
  • myers647
  • Visitor
  • Visitor
18 Sep 2011 18:53 #22108 by myers647
Ebay item number Item number: 290347893198 £91
  • Nelson83
  • Visitor
  • Visitor
19 Sep 2011 03:54 #22112 by Nelson83
Replied by Nelson83 on topic Re: Fitted new light pod
Dont suppose you (or anyone with a similar pod) can tell me or better still show pics of the wiring loom/ and / or how you plumb one of these into the electrics - im thinking about getting one and am wondering if its possible to wire them so they come on with with main beam and spots on my a bar, and but be able to turn them off independently. A wiring diagram would be ideal :-)
19 Sep 2011 18:44 #22145 by ooky_123
Replied by ooky_123 on topic Re: Fitted new light pod
I have the oval version of these fitted...
Fitting really easy, all the wiring is colour coded and simple to connect ... all you need is to connect to a fused live and run a second power feed to a switched ancillary and make sure you earth the lot...
Former owner of Little "Ooky", who has now started a new life in Shetland
  • doncarlyon
  • Visitor
  • Visitor
20 Sep 2011 06:33 #22161 by doncarlyon
Replied by doncarlyon on topic Re: Fitted new light pod
Would like one if i can get it for a similar price to what you paid... wouldnt pay 100 notes for one.
20 Sep 2011 10:09 #22165 by ooky_123
Forgot to add, I sealed around the base of mine and filled the channels in the roof with black silicone sealer. Also filled in the gaps between the roof bars with silicone too. £100 may seem steep, but when you work it out, 4x spotlights will cost you £50 - £60 .. then add cables / connectors / relays / switch / fuses and that can be an extra £10 - £15 ... for the extra £30 you get an ABS pod and its a single unit rather than 4x separate lights that will all need aligning and fixing to something .. or each one drilled though a roofbar.
  • doncarlyon
  • Visitor
  • Visitor
21 Sep 2011 05:26 #22233 by doncarlyon
Yeah but im a tight northerner ha ha! ;)
  • Fearghal Murphy
  • Visitor
  • Visitor
21 Sep 2011 18:07 #22294 by Fearghal Murphy
Thanks very much for the link ! Has got me pointed in the right direction for sure ! Think these ones cud be a winner actually !
