Think it's the crank sensor ????
28 Jul 2011 05:00 #19619 by rusty spanner
After some time spent tying to get this jimny running swopping over all the sensors the only sensor that I don't have a spare of is a crank sensor and it seems the only place I can get one is from Suzuki at £73.00 d:-( is there any where on the net I can get one from at a lot less money can't find one on eBay or my parts place as my jimny will run for a min or two then cut out my obd code reader finds no foult codes
28 Jul 2011 05:04 #19620 by rusty spanner
Engine code g13bb
28 Jul 2011 05:56 #19622 by mlines
I have been chasing up sensors to stock on BigJimny. I have been in conversations with the Distributor who prematurely announced their arrival in May/June. The last statement from the manufacturer is that it will be the end of August. The excuse is that the Tsunami in Japan is creating a severe shortage of this type of component.
It will be no consolation to you to know that the sensors will range from £30 to £45 depending on the model/age of Jimny you have.
28 Jul 2011 05:59 #19623 by mlines
I should also state that generic (three wire and four wire) sensors are around and are available but as you have to plumb these into the wiring and, to some extent, guess on the sensor characteristics required, I have not stocked these as most BigJimny customers want a simple straight plug-in solution.
28 Jul 2011 06:21 #19624 by rusty spanner
Seams there is a lack of them out there as every where iv been in and around Milton Keynes are out of stock apart from Suzuki so this could be why
  • Keefe
28 Jul 2011 08:26 #19627 by Keefe
Replied by Keefe on topic Re: Think it's the crank sensor ????
I've got a spare, used crank sensor in the garage but it's for the 'M' motor, I presume they're different?
Time to create page: 1.327 seconds
