K and N On Jimny
- scrappybill
- Visitor
05 May 2011 20:41 - 05 May 2011 20:42 #15947
by scrappybill
K and N On Jimny was created by scrappybill
I took delivery of my K&N for my Jimny today. (For on road use only)
Took less than 5 mins to fit.
Just whipped out the standard air-box and panel filter, Made a 75mm x 60mm dia steel pipe/tube to couple up the original air intake pipe to the new K&N Tightened up the Jubilee clips.
Drilled a 10mm Hole for the Temperature sensor, (A Nice Push fit) in the side of the collar of the K&N
Job done.
Looks Well tidy- and sounds like my evo :woohoo:
I will knock up a stainless bracket to hold it up of the inner wing about 40mm and to hold it nice and sturdy.
If i need to put back the original airbox etc its 1 screw and 3 bolts, and 5mins of a change-over if that !!
And where the temperature sensor goes !!
Job done.
Last edit: 05 May 2011 20:42 by scrappybill. Reason: more info
- doncarlyon
- Visitor
06 May 2011 06:37 #15952
by doncarlyon
Replied by doncarlyon on topic Re: K and N On Jimny
Did you just do it for the noise or are you expecting it to be better in other ways?
- scrappybill
- Visitor
06 May 2011 07:58 #15955
by scrappybill
Replied by scrappybill on topic Re: K and N On Jimny
Noise + it will probably give me a few more bhp's and maybe a few miles to the gallon.
I have owned several high performance cars over the years, and have always used K&N's sometimes with very good results, on the gained BHP's .
38bhp on the mustang with the custom filter alone
I still have tuned 5.0L V8 Mustang Cobra with K&N and custom exhaust thats 402 Bhp
and a 3.5L V6 Pajero Evolution thats got a K&N with a tuned Custom Exhaust also as well as a few other bits and bobs thats 320bhp.
Even my Volvo T5 Coupe is around 280bhp with a few mods and the K&N
But on a 1.3L low powered engine the gains will be minimal.
If the engine was around 80bhp its now around 83-84 may be more.(Cone filters generally give more cfm and bigger BHP) either way I had all-ready calculated / measured that the airflow from the panel filter can not exceed 420 cfm, but the new K&N can allow up to 880 cfm
The engine draws over 600cfm at 4000rpm (No filter or pipe attached). so the standard panel filter actually chokes the engine
The noise alone makes it worth it
When i get round to making a nice shiny stainless bracket to lift it up slightly, it will look good aswell lol:P
I could have gone all the way and fitted alloy pipes and tubes etc etc, and fitted a bigger cone, But
I chose the K&N i have specifically because - all i needed to couple them up was a small length of 60mm steel or rigid tube (Its the diameter of the air intake pipe) the collar of the K&N actually allows the original air intake pipe to sit inside the lip of it, Making it a PERFECT fit.
Its not an "off the shelf" K&N its from the custom range they do, They make 1000's and have a huge chart of dimensions and other things you can specify.
- doncarlyon
- Visitor
06 May 2011 09:43 #15959
by doncarlyon
Ive got an ITG cone in the garage i might fit to mine, see if it makes any difference. They always feel faster when they make a bit of noise anyway lol.
Fitted a nice Pipercross RS500 cone to my Focus RS but i dont think it would fit in the Jimny engine bay lol.
06 May 2011 10:14 #15962
by ooky_123
Former owner of Little "Ooky", who has now started a new life in Shetland
Replied by ooky_123 on topic Re: K and N On Jimny
I went with a standard filter on the jimny. I run a K&N on the TVR that gave me an increase of about 25 bhp.
- DVs-Jimny
- Visitor
06 May 2011 12:29 - 06 May 2011 12:30 #15967
by DVs-Jimny
Replied by DVs-Jimny on topic Re: K and N On Jimny
TBH the Jimny engine bay gets too hot and that is bad for a cone filter and power (heat soak). If you do use one make sure you fit some ducting to get cold air. If your not going through big puddles then use the panel filter and get a hole cutter. Cut some 2" holes in the air box (make sure its the pre filtered side) and again use cold air ducting. Better improvements than a cone filter IMHO.
I had a modded ST24 (Bluefin chip, Janspeed decat pipe, Mongoose twin exit SS system, bigger TB etc etc. The KN cone was producing less power due to heat soak (dyno'd at Superchips), went over to the Pipercross Viper (has heat shield and ducting) and that gave a few extra ponies.
Last edit: 06 May 2011 12:30 by DVs-Jimny.
- doncarlyon
- Visitor
06 May 2011 12:57 #15968
by doncarlyon
Maybe just a bigger airbox would be a better idea then to stop the heat soak?
07 May 2011 11:44 #16004
by kirkynut
Replied by kirkynut on topic Re: K and N On Jimny
If you are fitting a cone filter to a Jimny, make sure it's for on road or very dry off road use only.
The original airbox is carefully designed to be able to cope with an amount of water, when you look at the route of the rubber intake pipe and then the bowl at the bottom of the airbox which has a hole in it to allow water to run out.
You don't have to go through that deep water to splash it over the airbox and a cone filter would just allow it to get sucked through if it got a soaking.
So just be careful when offroading with one!
If you were going to go out and buy one new, maybe the money would be better put towards a snorkel?
07 May 2011 16:52 #16016
by facade
Replied by facade on topic Re: K and N On Jimny
First thing my brother does to his cars is fit a cone filter. He reckons they go miles faster, I reckon they make too much noise.
I've driven a couple, they have no bottom end at all, and I can't get them to pull away without boy racer revs and clutch slipping. ( Golf GTI and some 5 cylinder fiat saloon with a funny name)
If you do fit one, keep all the original filter and fittings, if I came to buy the car my first question would be: "Do you have the original air filter?"
- doncarlyon
- Visitor
11 Aug 2011 09:43 #20182
by doncarlyon
Hows it going with the filter?
- ZookFastback
- Visitor
11 Aug 2011 10:46 #20185
by ZookFastback
Replied by ZookFastback on topic Re: K and N On Jimny
I would not use the type of filter you are talking about because they do not filter as much grit out of the air as a standard paper filter. Because they don't filter out as many particles they can suck more air in to give slight power gains but at the risk of premature engine failure due to abrasive particles not being filtered out of the intake.
Check this well-known article out for yourself... www.bobistheoilguy.com/airfilter/airtest1.htm
- fatwelly
- Visitor
12 Aug 2011 07:33 - 12 Aug 2011 07:35 #20229
by fatwelly
Replied by fatwelly on topic Re: K and N On Jimny
i would sugest needs cleaning every 6 months
with kn cleaner and needs re oiling after woulds to keep dust out
note i left the old air box in for off road use
there is cold air ducting to the kn one from inner wing one from the font
ps how do i add a pic to this post
Last edit: 12 Aug 2011 07:35 by fatwelly.
Time to create page: 0.205 seconds
