kirkynut loud screeching noise
- george
- Visitor
24 Mar 2011 10:27 #13952
by george
kirkynut loud screeching noise was created by george
thanks for the advice mate,i have not much experiance with freewheeling hubs its not the alternator belt.whats the procedure with the hubs
24 Mar 2011 14:35 #13955
by kirkynut
Replied by kirkynut on topic Re: kirkynut loud screeching noise
I've not had much to do with the vacuum operated ones so I'm not really the best person to tell you how to get them working properly if it is them.
I have some on the shelf in the garage so will have a look at them to remind myself what they look like.
I binned mine at the earliest opportunity and replaced them with fixed hubs and later manual freewheeling ones as they just work - rather than the will they, won't they affair with the vacuum ones. My vacuum ones did not want to work my first time out greenlaning in the Jimny and it was a pain in the backside.
I'll get back to you if no-one else with more knowledge on the vacuum ones comes along to help you with their knowledge.
24 Mar 2011 15:09 #13958
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: kirkynut loud screeching noise
This might help fixing vacuum hubs in the field by MARTIN.
www.bigjimny.com/index.php?option=com_co...drivechain&Itemid=37
2002 JLX Soft Top
24 Mar 2011 16:42 #13965
by kirkynut
There you go then.
I would take it off, see if the centre part that slides in and out with the vacuum is seized and if it has witness marks from being caught - making the noise - free it up if it has with WD40 and tapping it lightly, and then work it so that it runs along the splines in and out till free and LIGHTLY grease it.
Make sure you don't damage the rubber seal that goes around the outside of the housing as this makes it air tight for the vacuum to work.
If there are no witness marks from it catching this is not causing the noise.
The only other thing I can think of is something seizing.
Have you had it up on a jack and spun the wheels to listen to where it might be coming from?
- george
- Visitor
24 Mar 2011 19:43 #13988
by george
Replied by george on topic Re: kirkynut loud screeching noise
had a look at the hubs may use your example and fit manual ones are these vacume ones a pain then.the hubs appear to be stuck in 4wd position though i cannot see any marks to suggest a problem.i have freed them up as martin suggested but one question i have is if they were stuck in 4wd why would they make a noise when 4wd is engaged.
24 Mar 2011 20:04 #13993
Replied by mlines on topic Re: kirkynut loud screeching noise
Its not a broken CV joint is it, the screeching being the inner rotating inside the outer?
Time to create page: 0.156 seconds
