Auto welding mask
- Johnniehec
Topic Author
- Thank you received: 56
07 Feb 2011 11:42 #11153
by Johnniehec
Auto welding mask was created by Johnniehec
Does anyone use one of these?
cgi.ebay.co.uk/Auto-Darkening-Solar-Weld...&hash=item19c2bca847
I'm still using a hand held visor but with sills to be welded auto has got to be the way to go! Is £20 false economy? The Aberdonian in me is attracted to this price!! Seems to be down to viewing window size, the cheapies seem to be about 90 X 40 mm. Is there any advantage in spending £50, £200 or more?
Cheers,
john.
Cheers,
john.
07 Feb 2011 11:53 #11154
Replied by mlines on topic Re: Auto welding mask
I have one and its fine apart from one issue. It does not fit my head well and the head adjustment is poor. Unless it is done up tightly it "flops" down during use. I guess thats one of the key differences, the expensive ones are designed to be used all day, every day comfortably. This one is only suitable for occasional use.
- biggaz
07 Feb 2011 12:02 #11156
by biggaz
Replied by biggaz on topic Re: Auto welding mask
This is usefull i was thinking exactly the same!
Thanks, sounds ok for me then although i have a large head! Machinemart have them for £60 but didnt fancy paying that..
Martin are they better to weld with than the handheld, apart from the obvious bonus of having two hands available?
07 Feb 2011 12:11 #11157
Much better than the handheld.
There is another small problem. The darkening feature reacts to normal bright light so if you are working with bright lighting to prepare and adjust your work it keeps going dark at inappropriate moments.
- trextr7monkey
07 Feb 2011 16:07 #11159
by trextr7monkey
Replied by trextr7monkey on topic Re: Auto welding mask
We have a Sealey one and a Machine mart jobbie, both seem decent enough but weren't cheap, if the e bay guys can do them for less then then go foir it, after all it is a welding helmet and will take a few knocks and drops.
We always wear hats under the helmet which overcomes the difficulties of kids with small heads.
No comparison with the hand held things. Its like the difference between the caveman's axe and a laser
- vitara_mad
07 Feb 2011 16:14 #11161
by vitara_mad
Replied by vitara_mad on topic Re: Auto welding mask
ive had one of the cheap ebay ones for about 2 years now its exelent & would not have a standard welding mask ever again
get one you won't regret it
Time to create page: 0.261 seconds
