shock absorbers, which are best?
  • panosd
06 Feb 2011 14:02 #11093 by panosd
Replied by panosd on topic Re: shock absorbers, which are best?
Why don't you try OME (Old Man Emu) or rancho shocks?
OME have a more smooth response than pro-comps and they are not so stiff as them.
Tell me your height to tell you shock codes.
Also the rancho rs5000 or the rs9000xl with the last one being adjustable are an excellent choice.
I have OME's in my jimny since i start making mods and are the best for me.
My next will be rancho rs9000xl with my ride system to adjust them from inside.
07 Feb 2011 17:46 #11163 by Obarno
I too have OME and find them comfortable on the road and flexible off so quite impressed. I also have them on my Sammi and after about 4 yrs of use/abuse they perform just as they did when they were new! Conversely my brother has Rough Country on his Jimny and they give a much harder ride.
09 Feb 2011 07:59 #11212 by mlines
Although the shop has not been up dated I can do Rough Country Shocks for £40 each + postage and packing.
  • Monkey
10 Feb 2011 07:36 #11297 by Monkey
Replied by Monkey on topic Re: shock absorbers, which are best?
Tough Dog shocks are good, i have them on my jimny they come in many different lengths from 40mm, 60mm and 80mm, they also offer a 3 year warranty. www.4wd1.com/Jimny.htm#suspension
  • bryandenham
10 Feb 2011 20:27 #11353 by bryandenham
Replied by bryandenham on topic Re: shock absorbers, which are best?
hey panosd.
what OME shocks would I need for a three inch lifted Jimny and where can I get them from.
Thanks. Bryan D
  • Ranster
11 Feb 2011 17:21 #11395 by Ranster
Replied by Ranster on topic Re: shock absorbers, which are best?
Just fitted the 3" procomp ES1000 kit.
It is less stiff then my previous setup - king spring with monroe adventure HD shocks - which is less stiff then the stock setup.
