Which jimny engine is best?
- Bannerbrother
- Visitor
My buget is around £2000 maybe £2500 but id like to know which is the best engine to go for (1298 / 1328 / vvt ) and what ill roughly get for my £££???
- ypvs jimny 350
- Visitor
- darthloachie
- Visitor
as to which engine you get depends on whether you want a soft top or a hard top as the earlier engine was still used in the softtop for a few years after the hard top moved to the twin cam
- biggaz
- Visitor
However, you will have more choice for your budget at a y plate ish one with a few mods... save you a lot of cash and cheaper tax.... its a toss up to be honest.
- Bannerbrother
- Visitor
I definatly want a hard top, so will prob go for the twin cam engine especialy if everyone rekons its stronger, as im going to be doing a 40-50 mile a day commute into birmingham so want the strength and reliability. i might have a little less choice in my budget and slightly more expensive tax but you cant win all the time.
- biggaz
- Visitor
heres a quick price list..
lift 2-3"? £300-400?
Extended hoses £60?
Castor correction £100?
Panhard Rods £200
Tyres £300?
it massivly mounts up, thats a basic list if you wanted to lift it and some approx prices.. Depending on what you want to do to it it may be much more cost effective to buy a "modified" one, i wish i did now! They go for the same sort of money as standard ones.
Half the fun is fitting stuff and making it your own but now if i was to do it again, id buy one with the above done and put the other money into protection/winch/transfer upgrade or similar.
hth gaz.
- Red One
- Visitor
- Smoggy
- Visitor
Cheaper tax, but comes with more rust, the later ones were galvanised, but still rust badly underneath if neglected. (seen a couple much later than mine very rusty underneath from unwashed mud and salt)
- v8dougie
- Visitor
Cheers
- biggaz
- Visitor
- darthloachie
- Visitor
v8dougie wrote: Is it possible to "drop" a twin cam engine into a car originally fitted with a single cam? If so what would need to be done? And what benefits would you find?
Cheers
the only benefit is a cam chain rather than a cam belt
If you're gonna go to the hassle of an engine change fit a G16B engine from a vitara, swift or baleno and you get a 1.6 with more torque - Martin does a fitting kit on here
I have the early 1.3 and its done 128k and still going strong - copes with 31" tyres and powering two alternators a roll cage and a hefty steel winch bumper without too many problems
