Deluxs black jimny, Project 'Yap'
05 Nov 2018 12:54 #197318
by Delux
Busiest Mechanic in Scotland!
My pics (inc. pics of my latest Jimny project)...
www.flickr.com/photos/159422664@N08/albums
My ebay stuff for sale...
www.ebay.co.uk/usr/deeelux
Deluxs black jimny, Project 'Yap' was created by Delux
I had been looking for a project since moving to a house with a garage. Unfortunately the garage is tiny so I am limited to what I can fit in it. The Jimny fits perfectly! So with that in mind, while under the influence of delicious fruit cider waiting for Mrs. Delux to get ready to go out, I drifted onto ebay and bought this...
s2-l1600
by
deeelux deeelux
, on Flickr
Didnt look or sound too bad and the reg seemed to suit Mrs. Delux. Problem was it was in Leominster, 400 miles away from me!
Anyway, 1 megabus, 1 train, 1 bemused taxi ride into the countryside, 400 miles, 1 KFC, 1 burger king and £50 petrol, 1 bucket of soapy water later and my driveway looked like this...
20170604_174246
by
deeelux deeelux
, on Flickr
[url=https://flic.kr
/p/2cF6NAa]20170604_174258[/url] by deeelux deeelux , on Flickr
Then I looked underneath...
20170729_140234
by
deeelux deeelux
, on Flickr
20170729_140209
by
deeelux deeelux
, on Flickr
It turns out being packed in mud might work to preserve 1000 year old farmers in Scandanavia but it doesnt seem to work so well on Suzuki Jimnys!
I was under no illusion, it had been advertised as spares or repairs, the seller stated his mechanic had told him it would need welded and it had been used as a farm runabout for years.
Anyway, I am no motoring journalist so there are loads of things I could have taken pics of while repairing but never thought to do so and I have not built some sort of greenlane ditch digging monster.
05 Nov 2018 13:18 #197320
by Delux
Replied by Delux on topic Deluxs black jimny, Project 'Yap'
To gain access to the rot, the back axle, prop and fuel tank were removed. I decided to weld the chassis 1st as it looked like the easiest to access. Several sections were cut out and replaced. As the metal is thicker than normal bodywork the repairs took longer as more of my time was taken up sliding back out from under the Jimny to reset the puny 13amp circuit breaker!
20171111_133336
by
deeelux deeelux
, on Flickr
After welding the chassis back together and stripping out pretty much all the interior I was able to patch up the bodywork...
20171118_110618
by
deeelux deeelux
, on Flickr
Everything was saturated in dinitrol or hammerite and stuck back together. Suspension was treated to some new poly bushes (because the old ones were knackered) and new rear shock absorbers (cos they were cheap and shiney) Brake pipes were replaced too (cos they were rotten)
20171230_123720
by
deeelux deeelux
, on Flickr
20171230_123740
by
deeelux deeelux
, on Flickr
This pic doesnt look very spectacular but I spent ages removing rusty mounting bolts, rusty brake pipe ends, freeing mechanism off and setting it back up...
20171230_123819
by
deeelux deeelux
, on Flickr
05 Nov 2018 16:14 #197334
by Delux
Front end was pretty much ok.
Had usual sticky brakes so everything was freed off and treated to new pads and discs
20180113_124010
by
deeelux deeelux
, on Flickr
Suspension arms were treated to a shiney thick layer of hammerite and new bushes. 4wd piping changed to orange silicone to ensure the MOT tester laughed!
20180127_114730
by
deeelux deeelux
, on Flickr
20180127_114807
by
deeelux deeelux
, on Flickr
(Yes, I put the nut on the suspension bush bolt soon after the pics were taken!)
On ebay you get quite a lot of silicone pipe for your money!
20180114_132242
by
deeelux deeelux
, on Flickr
What you see here isn't the whole story. I never took pics of changing the gearbox mount, fitting a steering damper, rewiring the front foglights, replacing the aerial, repairing the gearchange, repairing the exhaust etc. etc. I will next time!
20180929_091953
by
deeelux deeelux
, on Flickr
20180929_091520
by
deeelux deeelux
, on Flickr
So with it all back together and a bag of bribery krispy kreme donuts I headed off to the MOT station....
...where it failed!
...where it failed!
05 Nov 2018 17:48 #197341
Replied by Riccy on topic Deluxs black jimny, Project 'Yap'
A good read with a cliffhanger at the end!
Come on then, whats it failed on???
05 Nov 2018 19:47 #197347
by Delux
20180811_113919
by
deeelux deeelux
, on Flickr
Wellll....
No sidelights!
When I had the rear bumper off I removed the wiring loom, cleaned it up and retaped it, the number plate connectors looked a bit corroded. I didnt want to head into work just for 4 brass terminals so I cut them off and replaced them with normal female spade connectors. They were a bit tight so I taped them up a bit to stop them shorting out. However, by the time I drove to the MOT station they were shorting out and had blown the fuse. I had to jump up onto the ramp, diagnose and repair them before the MOT tester finished the test! So basically, I fixed something and made it worse!
20180929_114553
by
deeelux deeelux
, on Flickr
20180929_114531
by
deeelux deeelux
, on Flickr
Other than that, it passed with an advisory for the N/S/F tyre being worn on the outer edge. Front tyres were treated to some nice new Dunlops and the tracking was adjusted (1st time since it left Japan, I think!)
Connectors have been replaced with better ones!
Wellll....
No sidelights!
05 Nov 2018 20:07 #197350
by Delux
Hi Mark. Not sure what you mean! The wheel nuts are 19mm.
I seem to remember them being an option on the higher spec ones. They have special tube shaped wheel nuts. They can be a bit tricky to refit.
I have not measured the thread but M12/1.25 sounds about right.
Time to create page: 0.414 seconds
