Has anyone fitted speakers?
  • SB1500
30 Apr 2014 22:33 #113832 by SB1500
Has anyone fitted speakers? was created by SB1500
Not sure if I'm posting in the right place - please move it if not!
But I'm wondering if any of you have fitted better speakers or multimedia systems in your Jimny's and some info like the factory speaker setup (how many speakers, where they're located etc)
Thanks
  • Jimny_Aus
30 Apr 2014 22:47 #113833 by Jimny_Aus
Replied by Jimny_Aus on topic Has anyone fitted speakers?
yea i fitted a new CD player... nothing flash needed a tray to sit under it because the standard one is a bit big,
it wasn't the cleanest fit because the stock one has a unusual curve in the corners but does the job... ill be wiring up some rear speakers in the coming weeks when i get time....
its pretty straight forward...
30 Apr 2014 22:56 #113836 by Busta
Replied by Busta on topic Has anyone fitted speakers?
Standard setup is 2 speakers, one in each footwell. There are wires and cut-outs for 2 rear speakers behind the rear trim panels but most don't have rear speakers fitted. If upgrading the front speakers, check the mounting depth first as they need to be fairly slim.
Early models came with a single-din Clarion CD headunit which is adequate but easy to replace with any standard single-din headunit.
Later models come with a double-din head unit which is also adequate but easy to replace with a single or double-din unit. The trim around the standard headunit is a non-standard shape so a trim panel is needed if you are worried how it looks.
The following user(s) said Thank You: SB1500
  • SB1500
30 Apr 2014 23:00 #113837 by SB1500
Replied by SB1500 on topic Re:Has anyone fitted speakers?
Excellent! Thanks for your reply, that's exactly the kind of info needed! If anyone else wants to share their experiences with this I'd also love to hear!
01 May 2014 05:59 #113850 by Halford
Replied by Halford on topic Has anyone fitted speakers?
youy're right, you've posted in the wrong section,
should have put it in the tech section, this is for peeps building trucks.
never mind,
but you should try searching first as they're hundreds of posts on this topic and now there's 101
best to google using the term speakers site:bigjimny.com you can search for anything eg radio site:bigjimny.com
  • Wiltec17
01 May 2014 12:59 #113890 by Wiltec17
Replied by Wiltec17 on topic Has anyone fitted speakers?
I've got sony head unit and speakers, improved sound greatly! I meen your not going to get great sound quality from any type of system without adding a whole load of sound deadening as the jimny is quite a tinny beast, but i can now listen to my music fairly loud without the distortion that I used to get from the standard set up.
Speaker size is small, 10cm I believe. I'm sure someone can correct me it was a while ago I fitted them.
Time to create page: 0.176 seconds
