rear rocovery brackets
  • Fingers
06 May 2011 09:05 #15958 by Fingers
rear rocovery brackets was created by Fingers
Any photo's of the Big jimny shop bolt on rear recovery brackets fitted??
or a drawing or explanation of how they fit to the chassis?
Also could you fit one of the Big jimny bolt on rear recovery points to each side, as in each chassis rail??
cheers Jon
  • doncarlyon
06 May 2011 09:46 #15960 by doncarlyon
Replied by doncarlyon on topic Re: rear rocovery brackets
Also, can you fit them to the front of the car?
  • doncarlyon
26 May 2011 09:24 #16953 by doncarlyon
anyone?
26 May 2011 12:40 #16956 by mlines
Replied by mlines on topic Re: rear rocovery brackets
Sorry, missed this post, will reply this evening with the pictures.
We have a front bracket being prototyped soon
26 May 2011 16:52 - 26 May 2011 16:53 #16960 by mlines
The bracket fits under the rear of the car and bolts up and over the top of the chassis rail. A third bolt in the centre of the bracket locates in a chassis hole to help secure it against movement. In the picture is an additional chassis cross-member that you will not have on your car and it is scribbled out with pen in the picture.
Attachment bracketfit1.jpg not found
Attachment bracketfit2.jpg not found
The end of the bracket then hangs down in order to clear the bottom of a standard plastic rear bumper. It is not lower than the axle/diff/arms so should not contact the ground.
Last edit: 26 May 2011 16:53 by mlines.
  • doncarlyon
26 May 2011 17:10 #16962 by doncarlyon
It looks MASSIVE in that picture... what sort of dimensions are they?
Time to create page: 0.254 seconds
