New product under test
17 Jul 2009 16:27 #1024 by mlines
Thanks to Chris Heal the shop now has a new product under test.
These fit onto the end of the rear shocks and (hopefully) fulfil two objectives:
1. They have offset holes so that the shock can be stepped backwards reducing the likelyhood of the spring and shock hitting each other, a classic problem with lifting springs and aftermarket shock absorbers.
2. They add in a second direction of rotation, hopefully stopping the shock from winding itself undone (drivers side) or winding itself tight (passenger side)
A third benefit is the artificial increase in shock absorber length by about 1 inch.
As stated these are going out on trial to see of they work, if they do then the final product will also be coated to protect against rust.
Can I take a quick straw poll on who would be interested in buying these if they went into full production?
On the subject of trials we have another product being prototyped. Does anyone have a standard Jimny (complete with standard plastic bumpers) who would be willing to pop over to Reading in Berkshire for the testing of a bolt on product. The only criteria being that you must off-road your Jimny in order to properly test for me.
  • ronm
19 Jul 2009 08:00 #1029 by ronm
Replied by ronm on topic Re:New product under test
Hi Martin
Would be interested in trying (purchasing) if quality of weld holds up. My drivers side lower shock bush seems to chew up regularly and i only have mild 2inch lift.Wasn't a guy in Sweden using something similar with some success !!!!!!!
Ronm
  • Baz2236
19 Jul 2009 18:43 #1032 by Baz2236
Replied by Baz2236 on topic Re:New product under test
My Rear shock bolt keeps falling out I just thought it was me I would be interested in them, I don't mind trying things out but your a far way away.
They look good and if it stops my nice shiny shocks hitting and falling out then I want them.
Baz
20 Jul 2009 06:00 #1037 by mlines
Replied by mlines on topic Re:New product under test
Well the prototypes are with Chris and Brett to try out (I am not doing a lot of off-roading this month.
The next item is a bolt on recovery point - hence the search for an unmodified Jimny to fit it to. Mine is too modified to act as a test bed.
  • mcjimny
20 Jul 2009 19:31 #1043 by mcjimny
Replied by mcjimny on topic Re:New product under test
I'm very interested in this. I've been scratching my head for ages over something more substantial. My trucks standard if its any help i just wont be off road for a few weeks. Do you have any more details on them? i'd be after a pair for the front and can only fit one on the rear probably now i've fitted a towbar.
  • ooky_123
20 Jul 2009 19:58 #1044 by ooky_123
Replied by ooky_123 on topic Re:New product under test
Interested in a pair of those please ...
As for a recovery point, again, 10mm or thicker please ... def will have one or two .. depending on how they will be designed to fit to the Vehicle, and if they donot foul my current recovery / modifications
