29/11/09 - Fitting SJ manual hubs
I have just made up some prototype parts that will enable you to fit SJ manual hubs to your Jimny, overcoming the issues with the Vacuum hubs. This kit will shortly be available to purchase in the shop. In the meantim, here is the guide so that you can start planning the fitting.
  9334 Hits
20/11/09 - Indicator UPDATE
Just an update...
  8660 Hits
17/11/09 - Indicator failure
So I went out today to collect some plywood for the boat (the roll cage makes an excellent roofrack!) and noticed when turning that all four indicators flashed. It doesn't matter which way you turn they all flash together. Fortunately the workshop manual is quite good and goes through a diagnostic to determine whats wrong and it diagnosed that the flasher relay has failed. Its marked up as a DENSO 065500-5350 flasher unit, Suzuki part 38610-84F00. A search of the Internet brought up nothing I can buy (unless I want it in lots of 100!) so its off to the Suzuki dealers (and I bet its not a cheap item!)
  8829 Hits
15/11/09 - CV problems
Folowing a busted CV joint - see Busted  I have spent the last couple of evenings fitting it.
  9373 Hits
08/11/09 - Iains' Jimny
Iain has sent in some pictures of his Jimny and I challenge any of the UK readers not to be jealous of the location - The Alps - not sure my Jimny would get to the Alps.
  9649 Hits
