Soeley's 2019 Black SZ5
- Thank you received: 1926
16 Feb 2019 18:04 #203328
Replied by Lambert on topic Soeley's 2019 Black SZ5
Not bad, and much more affordable.
- Thank you received: 576
03 Mar 2019 16:23 #204059
Replied by Soeley on topic Soeley's 2019 Black SZ5
Finally got round to upgrading the horn today with a Stebel Nautilus compact Air Horn. I've had this on my previous two vehicles as well. Took some doing to squeeze it in where the original sat. I had to separate the horns from the compressor. All wired in with a relay using the original horn wire to trigger the relay.
Standard horn
Removed the headlight for easier access.
Found an existing hole to mount the compressor to.
Standard horn
03 Mar 2019 18:20 #204064
Busy weekend for me. Fitted the reversing camera. Not a difficult task. Rear bumper removal, rear seat squab removed (not sure why?) rear quarter panel trim removed, passenger side sill cover and front foot well trim removed.
If you use the green line you get enough room to open the rear door and walk around it.
The yellow line just allows you to open it as seen against the garage door.
Red line puts spare tyre about 8 inches away.
- Guy 2
04 Mar 2019 15:03 #204105
by Guy 2
Replied by Guy 2 on topic Soeley's 2019 Black SZ5
Just found this thread. Thank you Soeley you've posted such good stuff here.
04 Mar 2019 21:10 #204125
Thank you
Guy 2 wrote: Just found this thread. Thank you Soeley you've posted such good stuff here.
Thank you
06 Mar 2019 13:30 #204193
by facade
Replied by facade on topic Soeley's 2019 Black SZ5
Where did you get the reversing camera? Is it a proper suzuki one and it switches through the infotainment system properly?
I'm thinking I might need one if I can't see out of the gangsta windows in the dark.
