Ola`s jimny project
  • OlaGB
23 Jul 2018 13:43 #194573 by OlaGB
yakuza wrote: Hi!
Still on 98 octane?
Mine is good now on 98. Had a 8 hour drive south to Stord on 98 and the car performed quite good. Worst was going home up Modalen area. too long uphill with 600kg trailer.
My Swift (m13 no VVT 90hp) has this punch on high revs that my Jimny has none of with its m16. the intake manifold and TB must be it it seems.
Have you checked if your exhaust manifold cat is OK?
Sounds like i have too start collecting parts but now my budget still suffers from holiday and low gears for my transfer.
Has your transfer gotten more silent? Still gear noise from mine, but much less. Will change the gear oil now that i soon have reached 1000km of use after installing.
Tested both 95 and 98 oct now, and no ign knock on either as far as i know..
Compared live reading of ignition also, and can not see any retardation of ignition on 95 vs 98oct. But for some reason, i have more torque on 98. I loose 3-4km/h up a local hill in 5th on 95, while i gain 5-8km/h on 98oct. Several attempts, same story.. Got to test 95 again later on.
I did have some knock on 98oct on stock intake actually, but only afer heating up the motor real good.
Cat looked OK when manifold was off, but i did not remove it. Regret that alittle now, maybe i will later on.
Transfer is alot quieter now! Oil change is on the todo list!
23 Jul 2018 15:01 #194582 by yakuza
sounds like the same "before" as mine is now then. only slight knock on 98 when abused. but I do have to run it almost empty on 95 and will only get full effect of the 98 on the second filling.
Wish I could measure the 2006+ m16a GV intake as they can be found in Norway.
removing the cat did not give much noticeable difference on mine even though it was 50% defect.
  • OlaGB
24 Nov 2018 08:18 #198090 by OlaGB
Not much been happening lately, mostly been driving.. :) 8000km now since i bought it, 6000 with the SSS motor, and all is working flawless.
SSS motor is running strong, especially after getting the M18 intake/TB on it. It`s also running alot better in the cold weather now, which tells me the ECU is a bit off on fuel/ignition.
Trailgear transfer gears also running fine, just a little more gear noise than stock. Low range sure is fun!
15mm lift spacers installed up front, to get back the height i lost on winch install.
Just about to install the last bits before winter kicks in , the lockers and HD shafts/knuckles. Been pushing this forward as its alot of work, but have to get it done now.. Hopefully in by this week.
Upgraded alternator is installed (measured to 85-90A while winching), and a new Exide EP450 50Ah 750CCA battery is going in over the weekend.
Bought a new set of winter stud tires for it, Hankook I-pike 235/75-15. Supposedly very good winter tires, havent tested them in snow yet but they are suprisingly quiet and nice to drive onroad with..
  • OlaGB
26 Nov 2018 13:45 #198176 by OlaGB
Ongoing, 2x air lockers, 4x HD shafts and wheel bearings. Everything at once..
Alot of work, but fun since ive never done differensial work before!
26 Nov 2018 17:56 #198186 by Riccy
Air lockers are fun! watch as you get anywhere at the flick of a switch :laugh:
  • OlaGB
27 Nov 2018 13:15 #198228 by OlaGB
Riccy wrote: Air lockers are fun! watch as you get anywhere at the flick of a switch :laugh:
Yup, had it in a 37" Land cruiser 120 arctic truck before, but the car was way to expensive to do real offroading in.. I think this will be alot more fun to play with!
Gonna get help from a buddy tonight, installing bearings all over, so no diff install before tomorrow..
Got in the compressor today, and all wiring/switches.. Only left to do tubing to diffs..
Time to create page: 0.231 seconds
