Re:My 01 Jimny, another Norwegian
- StergiosJimny
- Visitor
- MadsV
- Visitor
Well yes im still waiting for the transferbox so
- MadsV
- Visitor
- MadsV
- Visitor
They didnt see the radius arm to axle bushes that was bad, ill change them anyway!
- Thank you received: 333
Is that ones or twos? Will you have to return for it being checked again?MadsV wrote: Jimnys been on MOT, some faults i knew were coming like steering wheel and hazard horn. Two that i didnt know and havent even checked was too much movement on both the joints on the axle going from gearbox to transfer. Ordered two from big jimny.
And that axle should be replaced when you get the new transfer box?
I got loads of SJ gearbox/transfer axles for some reason. Only kept the ones with little or no slack.
I got till the end of the month so I have to get an appointment for mine now.
- MadsV
- Visitor
- Mikeharris666
- Visitor
- Thank you received: 1761
I know severe rust will pass the Norwegian MOT as long as its sharp edges cannot hurt a pedestrian or occupant of the car, or away from the places i mentioned.
But how can they see if it is badly welded or well done glued?
- Thank you received: 653
A thick coat of paint and nothing will be said at mot
Original floor is only spot welded then seam sealed
I'm prepping my Jimny for floor rust repair. Is rear floor welded at sides to wheel arches? OP seems to just sealed it only.
Jimny 1999 manual
