BigJimnyMeet 2024
× Tell us about your Jimny and post some pictures! Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Re:My 01 Jimny, another Norwegian
  • mdog18
  • Visitor
  • Visitor
29 Apr 2018 20:12 #192282 by mdog18
Replied by mdog18 on topic Re:My 01 Jimny, another Norwegian
Brilliant!
  • MadsV
  • Visitor
  • Visitor
07 May 2018 21:35 #192489 by MadsV
Replied by MadsV on topic Re:My 01 Jimny, another Norwegian
New rear engine mount today
A bit messy with oil or something up there.
Mounted the castor correction bushes also
They really should come with the lift kit, its much better to drive, hardly any trailing compared to before!
Planing the engine swap one of the coming weekends also
09 May 2018 05:46 #192535 by yakuza
MadsV wrote: New rear engine mount today
They really should!
Gearbox shaft seal leaking?
  • MadsV
  • Visitor
  • Visitor
09 May 2018 06:02 #192538 by MadsV
Not sure, its minimal leakage in that case. Never seen anything drip
  • MadsV
  • Visitor
  • Visitor
09 May 2018 20:42 #192571 by MadsV
Finally I can use the seat belts again :lol:
Testing some new foam, chemical guys pink stuff
  • MadsV
  • Visitor
  • Visitor
11 May 2018 20:38 #192607 by MadsV
Pulled the engine today
Hood and all cables off
Cleaned out the bell housing, was alot of oil spill there from the leaking engine. Pressure washed the rest of the engine bay.
Engines are on top dead center and ready to pull the cam sensor ring tomorrow.
Here are the two sumps, you can see that the small baleno one is wider than the jimny one. Cutting and welding them tomorrow! Hoping to maybe get it in the engine bay when saturday is over
  • Lambert's Avatar
12 May 2018 04:43 #192612 by Lambert
Cool.
  • MadsV
  • Visitor
  • Visitor
12 May 2018 11:02 #192616 by MadsV
Seems I get delayed until monday to get the engine in.. the flywheel bearing came out in pieces. Probably because I forgot to put a jack under the gearbox before pulling the engine apart from the box, tearing the bearing off.
Been all over the city looking for a bearing, but the shops that could have it are closed on saturday, of course.
Guess I can take my time getting everything ready, have to patch some rust holes also at the front thats not reachable when the radiator is in.
Here is the blanking plate for the rear of the head. Original with a rubber seal, metal gasket on the Baleno G16B. Sealed a little bit with rtv silicone also
  • OlaGB
  • Visitor
  • Visitor
12 May 2018 11:08 #192617 by OlaGB
Replied by OlaGB on topic Re:My 01 Jimny, another Norwegian
Good job so far.. I actually find it easier to just remove the gearbox before pulling out the motor, but ofcourse not as easy when the car is on the floor.
Did you check the flywheel for wear, as it looked alittle worn on the pictures?
  • MadsV
  • Visitor
  • Visitor
12 May 2018 11:16 #192618 by MadsV
It will do for now :lol:
The clutch has had its days so I should consider changing the flywheel later on
  • MadsV
  • Visitor
  • Visitor
12 May 2018 12:10 #192620 by MadsV
Nice to have some luck also!! A friend work at the service department at the Stressless factory next to my garage, they had a huge bearing stock!
  • MadsV
  • Visitor
  • Visitor
12 May 2018 14:30 #192621 by MadsV
New bearing in
Modified sump, spot weld first then took it off to complete weld. There was a threaded hole one cylinder behind that i could use for support bracket
Test fitted the sump before complete weld
No I have pulled the cam ring off
Time to create page: 0.160 seconds
Powered by Kunena Forum
