BigJimnyMeet 2024
stuck in 4x4 on site HELPPPPPP!! PLEASE. SOLVED!!!
- invincible
- Visitor
01 Aug 2019 09:29 #211706
by invincible
stuck in 4x4 on site HELPPPPPP!! PLEASE. was created by invincible
hello all, yesterday half way up whernside on a job the 4x4 light started flashing and she wont go back into 2wd. the switch on the dash 2wd one then broke, so i took the dash off took the switches apart to find a tiny yellow rubber hat not a spring in the micro switches. i swapped 4wd low switch to hopefully make the 2wd switch work. this hasnt worked, and seems stuck in 4x4, i have manual hubs so i unlocked em, but will she be ok to drive ? its just the front drive shaft will be engaged all the time right ? it wont do any damage will it? there is prob a 1000 threads but i have to get off to work again, any help much app guys.
ps m16 engine still not in grrrr!!!
- Thank you received: 1761
01 Aug 2019 09:59 #211708
Replied by Lambert on topic stuck in 4x4 on site HELPPPPPP!! PLEASE.
If you have manual hubs you can switch them to 2x4 and all will be good to go.
- Podge
- Visitor
01 Aug 2019 11:14 #211709
by Podge
Replied by Podge on topic stuck in 4x4 on site HELPPPPPP!! PLEASE.
It's fine to drive. Fuel consumption might be ever so slightly higher as theres a bit more drag on the drivetrain, you probably wouldn't notice it however
- invincible
- Visitor
01 Aug 2019 13:48 #211713
by invincible
Replied by invincible on topic stuck in 4x4 on site HELPPPPPP!! PLEASE.
yeah i did that lambert, but the front drive shaft will be contstanly turning and i cant get into 4 low if want to, maybe is wiring underneath? i did drive through river eden at appleby last week?
- invincible
- Visitor
01 Aug 2019 13:50 #211714
by invincible
cheers podge so nowt will knacker, its just i cant get low 4x4 now
01 Aug 2019 15:17 #211715
Yeah probably just yanked a wire by the transfer box. Bit of a pain to do but not impossible to get going easily.
- invincible
- Visitor
02 Aug 2019 19:14 #211747
by invincible
so just do some connectors under the transfer box lambert? started working intermittently today. i,m thinking same as cahp on an old thread , it electric??
02 Aug 2019 20:27 #211754
Because the box is electrically controlled it has wires coming out fairly low down at the back that are not especially well protected from physical damage. It is not uncommon for these to catch and pull. Sometimes they will look intact other times they can be hanging off completely. Either way it's unlikely that you will have enough wire to put something like a butt connector on the broken wire against the plug, meaning a new plug is probably easier to do. Like I said a pig but not impossible to do.
- invincible
- Visitor
03 Aug 2019 08:51 #211769
by invincible
cheers lambert, where can i get a new transfer box connector am a bit stuck, cheers mate
- Chezzy71
- Visitor
03 Aug 2019 18:31 #211784
by Chezzy71
Replied by Chezzy71 on topic stuck in 4x4 on site HELPPPPPP!! PLEASE.
Is it best practice to fit manual hubs...?
In case of this happening and your miles from home
I would be really worried about using 4 wheel drive when miles from home in case it got stuck like this
04 Aug 2019 05:03 #211795
It depends on how you intend to use the vehicle and how you feel about risk. There is a degree of reliability inherent in a simple solution. But that only goes so far. It is also the thin edge of an increasingly slippery slope of what if modifications. You can have the most competent vehicle able to do just about anything and you can still come home on a recovery truck if you're unlucky.
- invincible
- Visitor
04 Aug 2019 09:31 #211801
by invincible
chezzy , free hubs, i,d of been stuck in dent dale, and coming home on a truck, is a pain getting out , but not that much hassle. buy some free hubs and keep em in the jimny with the tools to swap em , and use the vac system until it breaks! there now thats the solution ,, jimny yeey!!
but lambert where do i get a fresh connector and buttons!!?? hummm
cheers guys
cheers guys
Time to create page: 0.121 seconds
