BigJimnyMeet 2024
× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Help please>> M16A swap engine not working
05 Jul 2017 14:51 - 05 Jul 2017 17:02 #182490 by Mr.m.y
HI
Jimny 2015 VVT Manual
WE swap m16a vvt from suzuki swift sport 2014
the engine would not wont to start
the engine is cranking but there no spark in the ignition
we try to check all sensor ..we cant interference with computer to read the data
we check all connector
please any help
i am always swap m18a
but this time my friend bring for me m16a vvt but its new 2014 ..there some different with ignition system that it has
i dont EGR install it because it dosent fit in m16a engine t
m18a has EGR system
Best regards
Last edit: 05 Jul 2017 17:02 by Mr.m.y.
05 Jul 2017 15:55 #182491 by Keithy
Engine ground good?
The following user(s) said Thank You: Mr.m.y
05 Jul 2017 17:00 #182493 by Mr.m.y
yes...
this my third swap
m18a has EGR system
05 Jul 2017 19:06 #182498 by Keithy
Is the trigger wheel the same?
06 Jul 2017 14:46 - 06 Jul 2017 19:31 #182512 by Mr.m.y
i want note m16a has 4 separate 4 ignition coils as you seen in the picture
Last edit: 06 Jul 2017 19:31 by Mr.m.y.
06 Jul 2017 18:39 #182519 by Keithy
Mr.m.y wrote: i want note m16a has 4 separate injectors as you seen in the picture
Ahh so you have 4 ignition coils....can't you change the cam cover and fit the wasted spark coils?
07 Jul 2017 08:18 #182527 by Mr.m.y
i swap the cover and indignation coil of m13a
now the problem i have petrol and low spark
07 Jul 2017 20:13 #182539 by Keithy
Did you check the engine is grounded?
Put a multimeter set on DC Volts from the negative terminal on the battery and the other to the engine block....anything over 0.5V I'd reground it.
Do the sensors have the same resistance value as the originals?
09 Jul 2017 14:06 #182569 by Mr.m.y
Thankyou Keithy
There was different in the trigger wheel
m13a 31 teeth
m16a 2014 vvt sport 30 teeth
any recommendation
09 Jul 2017 20:03 #182584 by Keithy
Damn that's hard cheese old chap....swap the trigger wheel?....it'll fit but it means dropping the sump removing the crank and 3 allen socket heads....it's a whole lot of work but it should be able to be managed by the ecu then.
12 Jul 2017 13:38 #182674 by Mr.m.y
we swap the trigger wheel
and the engine work great
thankyou all
12 Jul 2017 17:27 #182679 by Keithy
Mr.m.y wrote: we swap the trigger wheel
thankyou all
Nice one I'm pleased for you!
Time to create page: 0.166 seconds
Powered by Kunena Forum
