Boot jack
- jimnyonhigh
- Visitor
I need a jack for the car as it did not come with one, i have a trolley jack in the garage at home.
Could you recommend me a jack to go in the boot of the car.
The Jimny has a 4 inch lift, and i understand the stranded boot jack that comes with the car are really rubbish.
Could somebody point me in the right direction or give me advice where to get a good boot jack and how much i will be looking at.
Just need a simple jack in case i have a flat and need to put the spare wheel on.
- reaper
- Visitor
- goatboy
- Visitor
- Thank you received: 360
- jimnyonhigh
- Visitor
Just want something simple incase of a puncture.
Attachment not found
- jimnyonhigh
- Visitor
- Thank you received: 210
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
- Thank you received: 584
I have the jack out of a Rangerover/Discovery, 2000kg lift, two sections, and a shaped saddle to go around the axle tube. Cost £10 from a Landrover breaker.
Bit big for the tool tray, would need strapping in somehow.
- reaper
- Visitor
- jimnyonhigh
- Visitor
Cheers for the help and tips guys.
- Skinhead
- Visitor
jimnyonhigh wrote: Thanks for the reply Reaper, would a HEAVY DUTY 2 TON HYDRAULIC BOTTLE JACK LIFT be ok or should i get a higher ton, like 5 ?
I bought 1 of these, didnt use it, threw it in the shed. Simply because that saddle thingy is about the size of a 20p! If it had a bigger 1 it would be ok for a wheel change, just have to put it straight under the radius arm.
2002 JLX Soft Top
